WEAK VTEC
Old Mar 8, 2008 | 07:40 AM
squeeks's Avatar
Default WEAK VTEC
Vtec hits hard and strong after first start up but after about 20-30 mins of driving vtec doesnt seem to hit at all or really weak. I jus recently got my oil done but when I shut my car off for a few seconds and restart VTEC hits hard again so im guess it has to do with pressure. shed some light anyone?
b16a p30 ecu
Old Mar 8, 2008 | 07:51 AM
HAMOTORSPORTS's Avatar
Default Re: WEAK VTEC (squeeks)
Vtec either works or it doesnt. There isn't anyway for it to hit HARDER or WEAKER. If it is actually feeling significantly different, it is probably something to do with the iat or ect calibration in the ecu itself that is adjusting the fuel/ign maps when fully warm in an undesired way.
Old Mar 8, 2008 | 08:32 AM
devney's Avatar
Are you talking about the intensity of the sound?
Old Mar 8, 2008 | 08:48 AM
squeeks's Avatar
my mistake guys
for clarification
VTEC works fines AFTER first start up but after 20-30 mins you dont hear the AGGRESSIVE crossover nor feel the SLIGHT power difference, so im guessin its not hitting or its weak. I kno when and how its supposed to sound given the proper RPM and it jus doesnt feel or sound the same after 30 mins of running time
My boy got an LS and wen my vtec doesnt crossover were side by side on the high way
BUT wen i shut my car off for a few seconds and let it coast then restart you CLEARLY hear the crossover at 6k
VTEC works its jus afterawhile I have to restart it or ill get walkd on by LS integra and its getting fustrating with having to restart the car on the highway jus for the vtec to really kick in.
I dont kno its jus weird
Old Mar 8, 2008 | 08:56 AM
posHonda's Avatar
If youre on the highway and you downshift into your powerband than youre most likely going to be in VTEC so you wont hear the crossover.
What all do you have done?
Old Mar 8, 2008 | 09:56 AM
squeeks's Avatar
bone stock with an intake and im talkin about upshifting into vtec
Old Mar 8, 2008 | 10:04 AM
97Ej6mike's Avatar
Try a different ECU, change your oil, check the solonoid wiring, and check the grounds.
Old Mar 8, 2008 | 11:30 AM
posHonda's Avatar
Default Re: (squeeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squeeks &raquo;</TD></TR><TR><TD CLASS="quote">bone stock with an intake and im talkin about upshifting into vtec</TD></TR></TABLE>
In a racing situation with a b16 especially youd probably only only get to the vtec crossover point once and thats if its from a low roll or a dig. Otherwise youd be in vtec the entire time youre racing.
But I dont think thats youre problem. Im guessing its either low oil pressure or an electrical problem.
Old Mar 8, 2008 | 02:12 PM
.Radical_Edward.'s Avatar
Bounty - € 8,000,000
Default Re: (posHonda)
VTEC = Increase in power?
Old Mar 8, 2008 | 02:33 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (.Radical_Edward.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Radical_Edward. &raquo;</TD></TR><TR><TD CLASS="quote">VTEC = Increase in power?
OP: For VTEC to operate, the ECU needs to see:
-Coolant temp at operating temp (Via the CTS).
-Oil pressure
-VTEC hardware/software/wiring in good working order
-TPS reading above a certain throttle angle.
-Speed sensor reading above 15MPH
Are there any CELs on? Is all the above mentioned stuff in good working order?
VTEC operates or it does not operate. There's no middle ground. There may be intermittent operation, but that's also either on or off intermittently. It's a solenoid that forces a 3rd rocker into position so that the cams open the valves bigger. It's mechanical. Metal on metal. It's either operating or it's not.
Old Mar 8, 2008 | 04:43 PM
bitek's Avatar
check ur vtec solenoid for oil leaks
Old Mar 8, 2008 | 04:49 PM
SOHC_4dr's Avatar
it wont kick in at first start up if its cold. it has to reach opperating temp first in order for it to kick in
malo11
21
Dec 24, 2022 04:57 PM
Danielsb20crx
24
Jul 5, 2009 01:37 AM
civicking99
May 26, 2008 08:00 PM
91EF_Si
20
Sep 17, 2007 12:00 PM
92 bandit
Aug 24, 2006 09:04 AM
