boring problem
Old Mar 6, 2008 | 04:35 AM
02vtecsir's Avatar
Default boring problem
had a block bored to 82mm, but the shop did it without the pistons,i have 82mm wiseco 12:3:1 but it has more play then i am really comfortable with......what should i do...
it is a jdm b18c type r fully built????
Old Mar 6, 2008 | 06:34 AM
98vtec's Avatar
moderator emeritus
Default Re: boring problem (02vtecsir)
A) measure the clearance
If the bore is too large:
B) get another block bored and send the pistons with it
C) get bigger pistons and have it rebored
Old Mar 6, 2008 | 10:27 AM
mar778c's Avatar
Community Builder
Community Influencer
What is the clearance?
Old Mar 6, 2008 | 10:58 AM
Chris Tune's Avatar
Default Re: boring problem (98vtec)
wow a bit overboard without even knowing what clearance he got...
check the clearance... no one here can tell you without numbers.
Old Mar 6, 2008 | 11:08 AM
98vtec's Avatar
moderator emeritus
Default Re: boring problem (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">wow a bit overboard without even knowing what clearance he got...
check the clearance... no one here can tell you without numbers.</TD></TR></TABLE>
boring blindly
slim chance in hell that the machine shop met the clearance specs without having the pistons handy. I dont understand why a shop would even bore a block without knowing what it needed to go out to.
but yea, good advice on measuring the clearance. I'll add that to your options
Old Mar 6, 2008 | 12:03 PM
all-mtr-teg's Avatar
Sounds like you need to find a new machine shop
Old Mar 6, 2008 | 12:06 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02vtecsir &raquo;</TD></TR><TR><TD CLASS="quote">it is a jdm b18c type r fully built????</TD></TR></TABLE>
it is???????
Old Mar 6, 2008 | 12:11 PM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02vtecsir &raquo;</TD></TR><TR><TD CLASS="quote">had a block bored to 82mm, but the shop did it without the pistons,i have 82mm wiseco 12:3:1 but it has more play then i am really comfortable with......what should i do...
You're going to need to know how much clearance Wiseco recommends to know if you meet spec. They should be a bit looser than stock anyway, as forged pistons expand more than oem cast-type pistons. Get you're specs, then measure. If you are within specs, good. If the bores are too big, then you'll need new pistons and a new bore/hone. If it's too small...that's not as bad, because you'll just need a new bore/hone.
rh76pogi
34
Mar 22, 2008 09:00 AM
ekVtecPower
Jun 27, 2006 11:18 AM
*Boostwerks*
Jul 23, 2005 08:57 AM
1BadCvC
Mar 31, 2004 09:42 AM
crx1856
Nov 3, 2003 05:10 AM
