clifford 50.5x
Old Mar 3, 2008 | 12:12 PM
goldaccordse's Avatar
Default clifford 50.5x
I need an alarm for my car. Should I get the clifford 50.5x? Is this alarm any good? I dont think Ive seen a lot of ppl with this alarm
Old Mar 3, 2008 | 12:32 PM
White Smoke's Avatar
i my honda
Global Mod
Default Re: clifford 50.5x (goldaccordse)
Many people on this site use that alarm including myself. It's a great unit!
Which Alarm Should I Buy?
Old Mar 4, 2008 | 12:09 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: clifford 50.5x (White Smoke)
One of the best alarm out there. Only if its installed right.
Old Mar 8, 2008 | 10:18 PM
Just got this alarm installed today, is there anyway for me to adjust the sensitivity?
Old Mar 10, 2008 | 06:02 AM
i my honda
Global Mod
Default Re: (goldaccordse)
Which sensor do you want to adjust the sensitivity on? Did you have any other sensors added aside from the factory included shock sensor?
Old Mar 10, 2008 | 06:23 AM
i didnt get any extra sensors added. I want to adjust the shock sensors that came with the clifford to make it more sensitive. I've been shaking my car, and the alarm doesnt go off.
Old Mar 10, 2008 | 06:31 AM
i my honda
Global Mod
There is a screw/**** on the shock sensor that you have to turn to adjust sensitivity.
Old Mar 10, 2008 | 06:35 AM
how many shock sensors are there. I think I found one (its a little black box with a white ****) and which way to I turn it to make it more sensitive?
Old Mar 10, 2008 | 06:37 AM
i my honda
Global Mod
There is only one, sounds like you found it. I believe turning it clockwise will increases the sensitivity. Should be pretty easy to test.
Old Mar 10, 2008 | 06:42 AM
i turned the **** all the way in the clock wise direction, now when i tap the hood, it doesnt give off that warning beep, instead the alarm just triggers. but if i shake my car nothing happens. how do i fix that
Old Mar 10, 2008 | 07:35 AM
i my honda
Global Mod
Where is the sensor mounted? That sounds like the problem.
Old Mar 10, 2008 | 08:07 AM
its mounted under my dash (drivers side)
Old Mar 10, 2008 | 08:09 AM
i my honda
Global Mod
How is it mounted (IE:screws, zipties, tape) and to what exactly (IE: steering rack, firewall, metal support bracket)?
Old Mar 10, 2008 | 08:18 AM
Im pretty sure its mounted through zipties by the firewall
Old Mar 10, 2008 | 08:41 AM
i my honda
Global Mod
I have no clue what you mean. You will have to take pictures if you cannot describe it accurately enough. Sorry
Old Mar 10, 2008 | 08:42 AM
On the drivers side, where your gas pedal and brake is, if you look up on the left side, thats where my "brain" and shock sensor is located. It's like right in front of the firewall.
Old Mar 10, 2008 | 09:27 AM
94_DC4's Avatar
Where did you get the install done?
Old Mar 10, 2008 | 09:28 AM
shop called speed zone
Old Mar 10, 2008 | 09:53 AM
fcm's Avatar
fcm
Old Fart
Two things, you have turned the sensitivity up way too high, it is an impact sensor, not a motion sensor, shacking/rocking the car should not trigger the alarm, [full alarm or warn a way].
Turn the sensor down to where it was, then adjust it up a little bit, arm the alarm and supply shock to the car, hit the "A" or "B" pillars.
The sensitivity is correct when you can kick the tire hard and nothing more then the warn a way mode is triggered but if you crack a lug nut free it will trigger full alarming mode. 94
Old Mar 10, 2008 | 09:57 AM
what does hit the "a" or "b" pillars mean? And also, i originally had the honda remote door unlock, i was messing with it at first and didnt think it will still unlock/lock my doors, but it still does. Is it bad to use my clifford and sometimes my honda remote
Old Mar 10, 2008 | 10:54 AM
suspendedHatch's Avatar
I wouldn't expect so much from a shock sensor. If it doesn't go off when a motorcycle drives by, it's doing it's job as intended. They're great if someone is stealing your car with a bulldozer. I remove them on my cars and use more effective sensors in their place.
Old Mar 10, 2008 | 10:57 AM
lol. What kind of sensors are you using? And what do you think about cliffords proximity sensors? Should I get em?
Old Mar 11, 2008 | 04:52 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldaccordse &raquo;</TD></TR><TR><TD CLASS="quote">lol. What kind of sensors are you using? And what do you think about cliffords proximity sensors? Should I get em?</TD></TR></TABLE>
You really need to check out the stickys bro, and try using the search feature. This has all been covered before.
[HOW-TO:] Car Security
DEI proximity sensors are not that great, we recommend the Crimstopper AU94TM.
vinceiscoo
Audio / Security / Video
Aug 26, 2008 02:03 PM
otacon122
10
Feb 18, 2008 08:04 PM
Tonyl507
13
Feb 2, 2007 04:20 PM
preludexl
Jan 30, 2003 09:31 AM
AnythingTypeR
Jun 27, 2002 07:36 PM
