installing exedy stage 1 clutch
Old Feb 28, 2008 | 07:46 PM
dc2_916's Avatar
Default installing exedy stage 1 clutch
i was wonderin if u would need to take out the wheel to install the clutch.i lost the dam key to my wheel lock.. is there anywy i can still install it?
Old Feb 28, 2008 | 08:12 PM
HyperX's Avatar
Default Re: installing exedy stage 1 clutch (dc2_916)
u have to take off the wheel.
Old Feb 28, 2008 | 08:16 PM
GiT LaO'd's Avatar
LOL...Yes sir you have to take off the wheel...Hell you gotta pull the axle out too...Don't forget you have to drop that transmission as well...Don't forget the half shaft...The starter gotta come out too...Its not the hardest thing to do but having a cherry picker is BIG TIME HELP...Good luck buddy...
Old Feb 28, 2008 | 08:22 PM
mfzbike's Avatar
yup, both wheels both axles...bout a 5 hour job
Old Feb 28, 2008 | 08:32 PM
jhammond_82's Avatar
Reject Papi
Default Re: (mfzbike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GiT LaO’d &raquo;</TD></TR><TR><TD CLASS="quote">LOL...Yes sir you have to take off the wheel...Hell you gotta pull the axle out too...Don't forget you have to drop that transmission as well...Don't forget the half shaft...The starter gotta come out too...Its not the hardest thing to do but having a cherry picker is BIG TIME HELP...Good luck buddy...</TD></TR></TABLE> and then....and then....and then..... lol. op looks like you have your answer. you should do a how to with pics and a commentary and post it in the faq for future reference for other h-t goers.
Old Feb 28, 2008 | 08:35 PM
HONDACURA-DB8's Avatar
Depending on what kind of wheel locks you have, slam an old socket that will fit the wheel locks then brake them loose with your ratchet.
Old Feb 28, 2008 | 08:41 PM
Reject Papi
Default Re: (HONDACURA-DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDACURA-DB8 &raquo;</TD></TR><TR><TD CLASS="quote">Depending on what kind of wheel locks you have, slam an old socket that will fit the wheel locks then brake them loose with your ratchet.</TD></TR></TABLE> then what , replace the expletiveing lug nuts? alot of wheel dealers carry the locks, maybe they can sell you one, or let you borrow one. but why in the hell would you ruin lug nuts?
Old Feb 28, 2008 | 09:08 PM
The socket will get damaged b4 the wheel locks. I've done this quite a few times where customer lost the wheel lock key. You're right also, he can go to a wheel dealer and puchase a key that will match his wheel locks. But in desperate need, (not saying that he is) it's just another way of taking them off. No need to be an a$$ buddy...
Old Feb 28, 2008 | 10:15 PM
racebum's Avatar
doing an exedy stage one in my own GSR, local shops around here are doing it for 200-250, for that price i was game to let them do it. we'll see how it drives tomorrow. as for the wheel lock deal you might call around and see if a place like discount tire has one they will sell you or let you borrow. i mean it might not be a bad idea to just buy a new key
Old Mar 2, 2008 | 07:38 AM
dc2_916's Avatar
Default Re: (idrivesideways)
got my clutch installed and it grabbs like super hard.. second feels like my engine mount bouts to break off.. ha. im driving with a broken axle dam
Old Mar 2, 2008 | 07:45 AM
Tizight's Avatar
Default Re: (dc2_916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_916 &raquo;</TD></TR><TR><TD CLASS="quote">ha. im driving with a broken axle dam </TD></TR></TABLE>
When it ***** out on you it won't be funny.
Old Mar 2, 2008 | 10:31 AM
racebum's Avatar
mine grabs hard as well. i babied it for the first 200 miles just to let it set. thing hits hard now if you release quickly or soft if you slip it, it's also as easy to drive as stock. slightly more pedal pressure but it's not too much. the clucth that came out had torn rivits and this slice of metal from the hub area was laying there. cheap, no name auto parts store clutch.
Old Mar 2, 2008 | 11:16 AM
dc2_916's Avatar
Default Re: installing exedy stage 1 clutch (idrivesideways)
wat kinds of modds do u have on ur car,,
Adonis
Mar 16, 2009 03:07 PM
SIXTY
Mar 29, 2006 10:54 PM
twkdCD595
Jan 1, 2005 12:28 PM
clendaniel
Jan 24, 2004 10:55 AM
Hoosier Daddy
Nov 16, 2003 02:13 AM
