Which non twin-plate clutch to go with?
Honestly, I can't afford a $1,300 clutch right now. What other options do I have that can handle 300-400whp (just to be safe )
Thanks
Thanks
Re: Which non twin-plate clutch to go with? (InTeGrA B18b1)
Thank you sir
Should I break my motor in, then install a clutch or do it all at once? I should be fine doing it all at the same time right?
Re: Which non twin-plate clutch to go with? (Boost Creep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost Creep »</TD></TR><TR><TD CLASS="quote">Thank you sir
Should I break my motor in, then install a clutch or do it all at once? I should be fine doing it all at the same time right?</TD></TR></TABLE>
i say do it all at once so you can break in the motor/clutch. just drive like a grandma.
What exactly is the difference between sprung and unsprung? I think I'm gonna go with Action. Also, is it true that with boost you should stick with the stock flywheel?
Re: Which non twin-plate clutch to go with? (Evo Hybrid)
also harsher engagement vs softer
and get around a 12 lbs flywheel stock is close to 20 lbs which is a bit too heavy.
dont go too light either.
EKHWhat
02-25-2007 08:08 PM
drift2004
03-29-2005 11:06 PM
