timing question
Old Feb 28, 2008 | 02:44 AM
Blackice087's Avatar
Default timing question
ok i know this sounds is a stuiped questions but i've read that the red mark on a b18 is the timing mark and the white mark is used for tdc. but i've also read that the white mark is the timing mark and tdc. can someone explain why the other three marks are there and how they effect you the motor?
Old Feb 28, 2008 | 08:05 AM
Default Re: timing question (Blackice087)
bump
Old Feb 28, 2008 | 10:56 AM
HyperX's Avatar
the other 3 marks are btdc. someone correct me if i am wrong. those 3 marks are 14,16, and 18 deg btdc.
Old Feb 28, 2008 | 12:30 PM
95 integra's Avatar
Default Re: timing question (HyperX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperX &raquo;</TD></TR><TR><TD CLASS="quote">the other 3 marks are btdc. someone correct me if i am wrong. those 3 marks are 14,16, and 18 deg btdc.</TD></TR></TABLE>
Yes, as I recall the white mark is the TDC (0* mark) and the Red mark (one with 2 others around it) is 16* BTDC (the other 2 are +/- 2*s) and those are used to set your ignition timing.
Old Mar 21, 2008 | 06:40 PM
89Turbo_Angel's Avatar
I know this is kinda old, but what is the timing supposed to be set at?
We're doing this on a 99 GSR but can't find the info. I only see 2 white dots. No red like I've read.
Thanks in advance.
Juans_MX3
Apr 21, 2011 11:05 AM
blackbndt
Oct 4, 2009 10:20 AM
GReddy SI
Oct 21, 2004 06:41 AM
handa
13
Jul 31, 2004 05:19 PM
StlSupra
32
Oct 21, 2003 10:11 AM
