Serious Help needed....can you ghetto rig an oil feed line??
Old Feb 27, 2008 | 04:27 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Serious Help needed....can you ghetto rig an oil feed line??
ok, my oil feed line has a pretty serious leak to it. It's a used greddy 18g kit for a b-series engine and a random braided oil feed line. well the oil feed line leaks at the banjo hardline fitting where the braided line meets with the hardline. I have it circled in yellow where it leaks.
It is literally leaking about a 1/4 quart of fluid every 10 seconds, that's how bad the leak is. I really need to be able to drive this car until I can get another oil feed line ordered....what can I do aside from riding the bus??
stackz's Avatar
Community Builder
Default Re: Serious Help needed....can you ghetto rig an oil feed line?? (stackz)
Old Feb 27, 2008 | 04:28 PM
HickamHatch's Avatar
you can use barbed fittings and rubber hose with worm clamps till you can afford a good line
Old Feb 27, 2008 | 04:32 PM
stackz's Avatar
Community Builder
Default Re: Serious Help needed....can you ghetto rig an oil feed line?? (HickamHatch)
even with the heat in that area??
Old Feb 27, 2008 | 04:37 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HickamHatch &raquo;</TD></TR><TR><TD CLASS="quote">you can use barbed fittings and rubber hose with worm clamps till you can afford a good line</TD></TR></TABLE>
I did that with a heater hose back in 2003 when I didn't understand the concept of oil pressure (), and I have no idea how my motor lasted 8,000 miles before I switched to a proper -3 AN feed line.
However, I would suggest not doing it, for the sake of your motor/turbo. Talk to Stan @ Fast-Turbo about getting a replacement 18G oil feed line overnighted to you.
Old Feb 27, 2008 | 04:42 PM
stealthmode62's Avatar
I think you'll have better luck with a temperary fix if you route the line from the back and not over the turbo.
The inlet thread is m10x1.5. I would take a trip to ace and get creative for the time being.
Old Feb 28, 2008 | 01:49 PM
Bailhatch's Avatar
Default Re: Serious Help needed....can you ghetto rig an oil feed line?? (stealthmode62)
take some fuel injection hose and wrap tinfoil around it
PinoyDelS0l
Aug 30, 2009 12:43 AM
beepy
Mar 1, 2004 09:26 PM
DEVIN22CBR
Feb 5, 2004 04:08 PM
Diego Boost
Mar 10, 2003 01:20 PM
