questions about JRSC (I know they were "cool" 10yrs ago)???
Old Feb 26, 2008 | 06:59 AM
wfocrx's Avatar
Default questions about JRSC (I know they were "cool" 10yrs ago)???
I'am about to receive a JRSC that I bought from a member on d-series.org. I have a turbo crx that I'am building and have the ej1 for my DD. I had a couple questions still after doing a search...
1. is a new fuel pump needed for only ~150-180whp?
2. what size injectors would you recommend for 150-180whp?
3. I have an obd1 gsr tb laying around, will getting it portmatched to the spipe do anything?
4. should I run a catchcan setup simular to what I have/most people have on their turbo civics?
5. now that I hear jacksonracing/supercharger..com do not sell upgraded pullies how would I get ~8psi out of my d16z6?
6. has anyone decided on a decent cam yet?
7. would you recommend that I get my spare rebuilt extra head milled so I will have ~10:1 compression?
8.will h20/meth injection be good at lowering both actual IATs and the IAT that the ecu sees? reason I ask is because if it does that would make it almost full-proof since the p28 will retard proper timing if something were to ever happen to the h20/meth injection.
also, what are the typical IATs at ~8psi.
thanks. I will soon have 2 FI d-series.
Old Feb 26, 2008 | 08:00 AM
SovXietday's Avatar
Default Re: questions about JRSC (I know they were "cool" 10yrs ago)??? (wfocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">I'am about to receive a JRSC that I bought from a member on d-series.org. I have a turbo crx that I'am building and have the ej1 for my DD. I had a couple questions still after doing a search...
1) nope
2) stock will suffice, but you can do a set of 310s too.
3) Every little bit helps
4) I didn't, but it would be a good idea to at least releive the PCV system.
5) Put on a D16Y8 crank pulley. Other than that you'll need to get custom pulleys made (which is why I went turbo lol).
6) Zex 59300 or Bisimoto cam.
7) You're better off using new pistons. Shaving the deck height like that will screw up your combustion chamber and I don't know if you can shave the deck that much without throwing off the timing.
8) Won't hurt, but you're going to be going through meth/water more than you fill up for gas. It is nearly impossible to stay out of boost with the JRSCs. Average 8psi IAT temps are like 150ish, a little high but still safe.
Old Feb 26, 2008 | 08:11 AM
HiProfile's Avatar
Default Re: questions about JRSC (SovXietday)
The whole deal with the JRSC is that it makes a d16 feel like a B18, and basicly bolts right on. I'd definately go with 310's or 450's, just to be on the safe side.
You might want to go to a 10:1 head (with adjustable cam gear) if you're stuck at 6psi, since you'd essentially make more HP per PSI. The problem with going with a higher-psi pulley is that the JRSC's become inefficient above ~10psi. Unless you get the blower reworked by someone like Endyne, that extra boost will not help much at all - even with meth/h2o.
Also, don't forget - a decent header/exhaust helps too.
Old Feb 26, 2008 | 11:20 AM
wfocrx's Avatar
yeah, from doing some research on here I see that the kami header w/ the 2.5" collector seems best. I was also have a 2.5" exhaust made for the car. will I see anything with using a 62mm tb (I hear the s-pipe inlet is 62mm).
Also, since it is my DD and the engine in there now is healthy (~195-205 in all cyl) I would like to just throw on the rebuilt head after getting it milled .030 or .040 which should bring my static # up to ~10:1.
Old Feb 26, 2008 | 11:31 AM
creechrr's Avatar
I was JRSC'd at one point and I agree with most of what has been said above.
I used 310cc injectors without a problem. My compression was/is around 10.5:1. I also used the Zex cam. All tuned using Crome.
I eventually went turbo for two reasons:
1) The belt slippage on high RPM down shifts drove me crazy. A physically smaller pulley (high boost) would've even been worse.
2) I hadn't done turbo yet.
The turbo makes more power overall but, I miss the instant response of the SC. For a daily driver torque is wonderful thing. If you're going to be looking for high HP numbers look elsewhere. You're going to dump a ton of money into a JRSC to make 200+whp, especially on a D.
1999siguy
Oct 9, 2008 10:02 AM
Razr2
28
Feb 14, 2008 12:44 PM
cold_heart51
Jan 29, 2006 07:52 PM
brent_G
Jun 5, 2004 06:16 PM
Yellow Dragon
Jun 22, 2003 02:54 PM
