grinding problem...
Old Feb 24, 2008 | 12:58 PM
lakerholic34's Avatar
Default grinding problem...
i have a 99 civic ex.. and when i start my engine and release my clutch i start to hear a small grinding noise ... but when i step on the clutch it goes away... when i drive in 1st, 2nd an 3rd gear i occasionally hear grinding noise... does neone know whats wrong?? can it be the tranny or the clutch?? thanks for the help...
Old Feb 24, 2008 | 02:37 PM
Jason P's Avatar
Default Re: grinding problem... (lakerholic34)
I know this one!!!!!!!!!!!!!!!!
you need a new clutch its slipping
fix it fast so you dont mess up your tranny anymore
if I were you Id stop driving it until you get your clutch fixed
I have the same problem right now with my 93 del sol!
Waiting for my parts to come in
EBAY it =]
got a new exedy oe cluth, pressure plate, throwout bearing alignment tool for 90 bucks
or upgrade to stages if you prefer
change your tranny fluid if it hasnt been changed inawhile
Old Feb 24, 2008 | 04:42 PM
spray_bombed's Avatar
a slipping clutch isn't going to grind man....its more than likely your syncros in your trans going out....your mainshaft isnt at the same speed as your countershaft which is making your gears grind when shifting...does it do it at all in reverse?...because if it doesnt then it is your syncros because reverse isnt synchronized
Modified by spray_bombed at 10:59 AM 2/25/2008
spikenspud
Jan 22, 2007 08:50 AM
vruum vruum
Jan 13, 2006 12:10 PM
turbocivic0618
Oct 9, 2005 10:12 PM
maxheat
15
Jan 5, 2005 02:23 PM
SweetChin
Feb 28, 2002 02:41 AM
