Installing Suspension?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantoM.DA »</TD></TR><TR><TD CLASS="quote">what are you installing? like which components?</TD></TR></TABLE>im planning to install my ground control coilover..
https://honda-tech.com/zerothread/887859 - Popping lower balljoint
https://honda-tech.com/zerothread?id=230216 – ITR Sway Bars vs. Aftermarket
https://honda-tech.com/zerothread?id=161618 – Rear Subframe Discussion
https://honda-tech.com/zerothread?id=57813 – Strut and Sway Bar Discussion
https://honda-tech.com/zerothread?id=1183184 – GC/Koni vs. Tein Flex
https://honda-tech.com/zerothread?id=1045933 – Omnipower vs. Tein SS
https://honda-tech.com/zerothread?id=1103358 – Omnipower vs. Tein Flex
https://honda-tech.com/zerothread?id=975313 – Coilovers vs. Springs
https://honda-tech.com/zerothread?id=1192976 – Ebay Coilover Discussion
https://honda-tech.com/zerothread?id=1103213 – DA Coilover Discussion
https://honda-tech.com/zerothread?id=1194211 – Shock Discussion
https://honda-tech.com/zerothread?id=1135707 – ITR Shock Discussion
https://honda-tech.com/zerothread?id=957088 – Aftermarket Springs/Stock Shocks
https://honda-tech.com/zerothread?id=1202600 – Lower Mount Discussion
https://honda-tech.com/zerothread?id=1157855 - What Coilovers? Heres 2, Omnipower vs D2 *THANKS BLACK FIRE*
https://honda-tech.com/zerothread/1160671 - ABS Removal How-To *THANKS MIGS & MADNESS*
copied from the faq at the top of the integra forum page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/887859 - Popping lower balljoint
https://honda-tech.com/zerothread?id=1045933 – Omnipower vs. Tein SS wow thank you very much
Everything comes are pretty easy. I think the only tools you will need is a socket wrench, a 12 mm, 14 mm, and a 17 mm sockets. Only thing that you will need to be prepared for is the LCA bolts, they are a major PITA. Air tools work best for getting the lca bolts out.
Ideally you should have a spring compressor when taking the stock springs off your shocks, but not totally needed.
Good luck!
Good luck!
yeah, having spring compressors makes it safe. not having them makes it fun....because the shock shoots out from the spring, and so do all the washers. if your going that route, you can stand on the spring, and loosend the nut with an impact. you won't get hurt, but if you do it in a cluttered area, you'll spend forever looking for the hardware.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote">yeah, having spring compressors makes it safe. not having them makes it fun....because the shock shoots out from the spring, and so do all the washers. if your going that route, you can stand on the spring, and loosend the nut with an impact. you won't get hurt, but if you do it in a cluttered area, you'll spend forever looking for the hardware. </TD></TR></TABLE>
thanks good info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ketone »</TD></TR><TR><TD CLASS="quote">Everything comes are pretty easy. I think the only tools you will need is a socket wrench, a 12 mm, 14 mm, and a 17 mm sockets. Only thing that you will need to be prepared for is the LCA bolts, they are a major PITA. Air tools work best for getting the lca bolts out.
Good luck!</TD></TR></TABLE>thanks
thanks good info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JThrasher79 »</TD></TR><TR><TD CLASS="quote">i usually shoot the spring into the grass. lol</TD></TR></TABLE> thats what i "try" to do. most of the time they go down the driveway. lol. i tried shooting into a bucket once, and yeah, lets just say the only thing i accomplished was a welt on my leg. lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infamouskillas »</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...D=494
- this should help u...just take ur time and go pg by pg
</TD></TR></TABLE>this is the bet write up ever
thank you very much
thank you very much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote"> thats what i "try" to do. most of the time they go down the driveway. lol. i tried shooting into a bucket once, and yeah, lets just say the only thing i accomplished was a welt on my leg. lol. </TD></TR></TABLE>
sounds like it hurt.
i shot one off in a garage my first time, diddnt break anything but it could have. lol
KRiS1
Jun 13, 2003 01:52 PM
