Suspension install in Southern California
I just picked up prothane rear trailing arm bushings and SRR LCA's. Im looking for someone to install them in my area (909 ) unless you guys think they aren't too difficult to install myself.
Re: Suspension install in Southern California (POS Hatchback)
The bushings aren't that easy but a sledge hammer will help out a lot.
The LCA's.....well, do you have stock suspension or are you lowered?
If your lowered 2inches or more you can litterally jack up the back, put it on jack stands and swap out the 3 14mm bolts for each LCA and be done in 30 mins (first timer).
Re: Suspension install in Southern California (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">I have friends in Corona that will do it.</TD></TR></TABLE>
hook a brutha up
hook a brutha up
Then you just need to put the jack under the hub assembly and raise it a little till the holes match and then finish the last bolt.
