Suspension Techniques Swaybars Questions (need help)
I’m installing a set of suspension techniques swaybars on my ek and had lots of questions. I've open the box and found a **** load of bolts and crappy instructions. Just wondering if any of you guys have done this install and have any completed pictures or a set by step install process. Thanks
Also there web sit sucks *****!!!
have a friend give you a hand, it will make the install much more easier. it took me 3hrs to install the rear sways by myself. the fronts only took 1hr. the rears were a pain in the ***. good luck
first things first, make sure you have the right part #'s to begin with. i've had bad experiences with suspension techniques not sending the right bars. next, don't be swayed by all the bolts and nuts, they all form brackets and end links. the rear bar does require some drilling but is very easy to do. use an air drill if possible with a 90 degree head. depending on how much space you give the bottom holes, you might not be able to use washers on the bottom bolts. as for the rear sway bar end links, it is very easy if you compress the suspension first, this lines up the holes very well. and as always it's easier with two peeps. the front bar is very easy once you disconnect the exhaust and shift rods. you will sport a large wood once you drive it with them on.
good luck
good luck
KRiS1
Jun 13, 2003 01:52 PM
