injectors
Old Feb 22, 2008 | 08:18 PM
''Simon'''s Avatar
Default injectors
what is the differance for low impedance and high impedance injectors? i am in need of some new ones and i have a obd0 b16 with resester box if that make a differance in which i need. thanks for any help.
Old Feb 23, 2008 | 06:49 AM
ekBlackHatch's Avatar
what mods are done just get saturated i dont think u can get that small of peak/hold injector im guessing go with some 270cc for a b16 or 310cc at max unless u got alot of stuff done to it
Old Feb 23, 2008 | 12:09 PM
''Simon'''s Avatar
Default Re: (ekBlackHatch)
no im going to get some 440s. but i need to no the diff. im lookin to get some persicions. i have a stock b16 internaly but i have blox intake manifold, hytech replica header, passwordjdm whale *****,and NX honda NXL direct port 75 shot.
Old Feb 23, 2008 | 07:35 PM
''Simon'''s Avatar
Default Re: (''Simon'')
Old Feb 23, 2008 | 10:58 PM
lakaspeed's Avatar
LOW IMPEDANCE USE RESISTOR BOX ..LOW RESISTANCE
HIGH IMPEDANCE DOESNT NEED RESISTOR BOX ...HIGH RESISTANCE
IF U HAVE OBD0 SET UP UR GONNA NEED THE LOW IMPEDANCE INJECTORS
Old Feb 24, 2008 | 04:34 AM
''Simon'''s Avatar
Default Re: (lakaspeed)
thanks man thats all i needed to no
Old Feb 24, 2008 | 12:12 PM
GhostAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’’Simon’’ &raquo;</TD></TR><TR><TD CLASS="quote">no im going to get some 440s. but i need to no the diff. im lookin to get some persicions. i have a stock b16 internaly but i have blox intake manifold, hytech replica header, passwordjdm whale *****,and NX honda NXL direct port 75 shot.</TD></TR></TABLE>
For a build like yours I think 440's would be a bit overkill. A set of stock 240's should handle your mods. Unless your making over 200whp with it. If you do want to upgrade, maybe try a set of 92-96 Prelude low imp. 330(345)'s. You know that if you run larger injectors with your setup you will require tuning/fuel adjustments. What are you going to be using for fuel management?
Old Feb 24, 2008 | 05:33 PM
''Simon'''s Avatar
Default Re: (GhostAccord)
bre.
Old Feb 24, 2008 | 07:44 PM
MurtazaDSM
Mar 21, 2012 12:14 PM
Steeve_Civic
Dec 4, 2011 10:11 AM
93c1sol
Feb 11, 2009 09:42 AM
the.hamburglar
Aug 12, 2007 07:41 PM
CANTFAZZDISCHIT
Jan 7, 2005 05:54 PM
