RYWIRE... vtec for del sol????
Old Feb 18, 2008 | 08:18 AM
rewerbcrx's Avatar
Default RYWIRE... vtec for del sol????
non vtec del sol puitting a d16z6 in need wiring harness i guess??????????
Old Feb 18, 2008 | 09:24 AM
994door's Avatar
Default Re: RYWIRE... vtec for del sol???? (rewerbcrx)
Or you could wire it in yourself... its only one wire. Somewhere there is a pin location that I used with my swap.
Old Feb 18, 2008 | 09:49 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: RYWIRE... vtec for del sol???? (994door)
You might even score on that... I know the some of the older del sols already came wired for vtec. plug n play...
Old Feb 18, 2008 | 11:05 AM
rewerbcrx's Avatar
Default Re: RYWIRE... vtec for del sol???? (spAdam)
where would this one wire plug be located if it is there?
Old Feb 18, 2008 | 11:48 AM
fmrprojects's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door &raquo;</TD></TR><TR><TD CLASS="quote">Or you could wire it in yourself... its only one wire. Somewhere there is a pin location that I used with my swap.</TD></TR></TABLE>
actually its 3 wires. 1 for the ground on the pressure switch, 1 for the pressure signal. and the 3rd for vtec solenoid. i forgot where they go though i believe a4 and a14. correct me if im wrong
Old Feb 18, 2008 | 03:30 PM
rewerbcrx's Avatar
Default Re: RYWIRE... vtec for del sol???? (fmrprojects)
i would be better off if it was done by a jumper... i do not like to slop things around... thanks
is the civic DX the same wiring basically as the non vtec del sols?
Old Feb 18, 2008 | 03:54 PM
instrument's Avatar
if you did the swap yourself you should be able to manage putting 3 wires into the looom.
Old Feb 18, 2008 | 11:00 PM
rewerbcrx's Avatar
Default Re: (instrument)
all the swap involves is a drop in engine... this is why i am asking about the wiring... please don't assume you know me. i am just asking for advice thanks for helping
iknow rywire has a 92-95 civic dx wire jumper harness... what i would really like to know is if this would work for my 94 del sol non vtec that is getting a d16z6 (vtec engine) thanks again
Old Feb 19, 2008 | 05:57 AM
CapnKrunch's Avatar
Default Re: (rewerbcrx)
If you want to do 0 wiring and a P&P harness for that motor into your del sol get the 92-95 si/ex harness, you don't need the rywire harness.
Old Feb 19, 2008 | 08:42 AM
rewerbcrx's Avatar
Default Re: (CapnKrunch)
nah its a obd1 but thats for the option
DelSolid21
Sep 29, 2010 11:12 PM
civicminded93
Jun 18, 2008 09:35 AM
idriveadelsol7
Aug 28, 2005 09:51 AM
tcr03
10
Sep 2, 2004 11:26 AM
GSR_deLsOL
May 4, 2004 10:52 PM
