RYWIRE... vtec for del sol????
Re: RYWIRE... vtec for del sol???? (994door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door »</TD></TR><TR><TD CLASS="quote">Or you could wire it in yourself... its only one wire. Somewhere there is a pin location that I used with my swap.</TD></TR></TABLE>
actually its 3 wires. 1 for the ground on the pressure switch, 1 for the pressure signal. and the 3rd for vtec solenoid. i forgot where they go though i believe a4 and a14. correct me if im wrong
Re: RYWIRE... vtec for del sol???? (fmrprojects)
i would be better off if it was done by a jumper... i do not like to slop things around... thanks
is the civic DX the same wiring basically as the non vtec del sols?
Re: (instrument)
all the swap involves is a drop in engine... this is why i am asking about the wiring... please don't assume you know me. i am just asking for advice thanks for helping
iknow rywire has a 92-95 civic dx wire jumper harness... what i would really like to know is if this would work for my 94 del sol non vtec that is getting a d16z6 (vtec engine) thanks again
Re: (rewerbcrx)
If you want to do 0 wiring and a P&P harness for that motor into your del sol get the 92-95 si/ex harness, you don't need the rywire harness.
DelSolid21
09-29-2010 11:12 PM
civicminded93
06-18-2008 09:35 AM
GSR_deLsOL
05-04-2004 10:52 PM
