question for ppl who know anything about brakes
Old Feb 17, 2008 | 08:43 PM
gsr98integra's Avatar
Default question for ppl who know anything about brakes
Only one of my rear breaks hold when i have my e-brake on...
is there anything that i can check to see why only one is holding? Im kind of a diy person instead of taking it into a shop, so any ideas on what the problem could be would be appreciated
Old Feb 18, 2008 | 09:02 PM
Default Re: question for ppl who know anything about brakes (gsr98integra)
i guess no one knows much about e-brakes huh...
Old Feb 18, 2008 | 09:18 PM
2ndchirp's Avatar
Im guessin your car is 4-wheel disc-...the last time you changed your brakes did you or whoever did it touch or messed with the emergency brake cable that comes to the side that aint grabbing?
Old Feb 18, 2008 | 09:25 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: question for ppl who know anything about brakes (2ndchirp)
possibly a snapped cable?
Old Feb 18, 2008 | 09:26 PM
yea it has disc brakes and i did have some new brakes installed last year by a shop cause one calliper was sticking. Do you think that they might have forgotten to adjust something?
Old Feb 18, 2008 | 09:28 PM
2ndchirp's Avatar
Default Re: question for ppl who know anything about brakes (stocker2shocker91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 &raquo;</TD></TR><TR><TD CLASS="quote">possibly a snapped cable?</TD></TR></TABLE>
Yes thats also possible.. you would have to look at the good side and bad side and match it up...
Old Feb 18, 2008 | 09:38 PM
ok thanks for your help, ill look at both sides tomorrow and try to figure out why its not grabbing.
Old Feb 18, 2008 | 11:27 PM
Jimmy's Avatar
Global Moderator
Check to see if you need to tighten up the e brake cables.. You can do it by removing your console or on the rear caliper..
Old Feb 18, 2008 | 11:56 PM
98BabiGs-T's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr98integra &raquo;</TD></TR><TR><TD CLASS="quote">Only one of my rear breaks hold when i have my e-brake on...
is there anything that i can check to see why only one is holding? Im kind of a diy person instead of taking it into a shop, so any ideas on what the problem could be would be appreciated </TD></TR></TABLE>
How do you know only one of your breaks works/holds...? If you already know which side doesn't work then check the cable (from the handbrake to the brake).
To check it, simply have someone pull the E-brake while you inspect the E-brake cable. Make sure they are "tightening" up when the e-brake is pulled.
Old Feb 19, 2008 | 12:00 AM
Dark@Powers's Avatar
Default Re: (98BabiGs-T)
I believe you're supposed to lift up the console and tighten the cable. I think I saw an article some where on team-integra a while ago...
Old Feb 19, 2008 | 09:12 AM
Default Re: (Dark@Powers)
I've tightened the cables from the console in the car already, but that didnt help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">How do you know only one of your breaks works/holds...?</TD></TR></TABLE>
I know this because I took off my left rear tire a few days ago and in the process I forgot to loosen the lugs before the tire was off the ground... i had my e-brake on at the time but the wheel spun freely when i tried to take the lugs off.
Anyway, im going to check the cable from the console to the actual brake today and see what i can find.
Old Feb 19, 2008 | 07:17 PM
mjfx's Avatar
I have the same problem. I am assuming the cable is loose or something snapped but I have not had the time to fix it. Make sure you let us know what it was after you fix it. I noticed only one side of mine works because on a hill, after i put the ebrake and let go of the brake pedal, the left rear pops up a little because it wants to roll back. So yea let us know.
lex718
Sep 5, 2006 05:17 AM
coupe_hybrid
May 20, 2006 09:31 AM
hybridhonda826
12
Oct 17, 2004 11:30 AM
cash459
May 26, 2003 04:56 PM
