Ebrake don't work!! Help!!
Old May 18, 2006 | 06:46 PM
coupe_hybrid's Avatar
Default Ebrake don't work!! Help!!
My Ebrake recently stopped working anyone know what could be wrong with it? When I pull up the Ebrake Lever it still has tension like its working but car still rolls as if ebake wasn't on?
Old May 18, 2006 | 06:50 PM
DC_RaceR's Avatar
Default Re: Ebrake don't work!! Help!! (coupe_hybrid)
probably need brake change?
Bad Cable?
try to adjust the cable?
Old May 18, 2006 | 07:28 PM
Default Re: Ebrake don't work!! Help!! (DC_RaceR)
I'll check the brakes tommorow. I'll also try to adjust the cable
Old May 19, 2006 | 03:43 AM
JimBlake's Avatar
Get someone to help...
Drums or disks in the back??
Lift the car so you can see the rear brakes. The cable attaches to a lever on the drum backing plate, or on the caliper. When your friend pulls the handbrake lever, watch the cable.
If the cable never pulls, then look for problems with the cables being rusted & seized into their sheaths. Then you need new cables.
If the cable pulls but the lever won't move, then you gotta take apart the brakes. With drums it's kinda straightforward once the drum is off. Calipers need some strange snap-ring pliers to take apart the handbrake mechanism from inside the cylinder, so maybe that's an excuse to get rebuilt calipers.
With disk brakes, it's also possible the pads are rust-bound into the caliper brackets. In that case, your regular brakes are only working on the front...
Old May 19, 2006 | 06:44 PM
FallenAngelHIM's Avatar
i'm having a problem on my 6th gen LX where my e-brake light comes on when it's cold. if i leave the car over a cold night and turn it on in the morning the e-brake light turns on. after 10-15 minutes of driving it goes away. i also noticed that when i made a hard turn today while it was off, it came on. then after a bit of driving it went away complete with or without hard turns.
Old May 19, 2006 | 10:05 PM
H2290's Avatar
Default Re: (FallenAngelHIM)
Try adding some brake fluid.
Old May 20, 2006 | 04:13 AM
**** I think something else is wrong with it. Tried adjusting yesterday and even though when the adjustment bolt was tightened all the way the wheels were still spinning with ease with absolutely no drag at all. Could it be that the rear calipers aren't even working anymore? Is that possible? Or what should I look at next.
Old May 20, 2006 | 04:49 AM
Ross 2.0's Avatar
In a Junkyard near you.
hmm I bet you have drum brakes and someone drove the car with the parking brake on and burned the linings off. In this case when you pull the handle the metal of the brake shoes will contact the drum but not provide any stopping force because it's just metal to metal.
Also knowing year and model would help
Old May 20, 2006 | 07:24 AM
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">hmm I bet you have drum brakes and someone drove the car with the parking brake on and burned the linings off. In this case when you pull the handle the metal of the brake shoes will contact the drum but not provide any stopping force because it's just metal to metal.
Also knowing year and model would help</TD></TR></TABLE>
My bad the accord is a ex and it has rear disc brakes.
Old May 20, 2006 | 09:31 AM
hondadude's Avatar
Default Re: (coupe_hybrid)
There should be a sticker under the hood to tell you WHAT YEAR the car is
760PhatBoyz
Suspension & Brakes
Sep 9, 2010 02:43 AM
HondaHeddie
Feb 14, 2007 11:40 AM
Mag00n
Sep 12, 2005 09:22 AM
