Does this sound like a bad distributor bearing or maybe rotor?
Old Feb 17, 2008 | 12:11 PM
b.d.racing's Avatar
Default Does this sound like a bad distributor bearing or maybe rotor?
Car is a 92 civic VX D15z1. Distributor has started making noise like there is something rattling around in there. I took off the cap and everything looked fine. Do I dish out the dough for a new dizzy or check something else?
Old Feb 18, 2008 | 10:29 AM
b.d.racing's Avatar
Default Re: Does this sound like a bad distributor bearing or maybe rotor? (b.d.racing)
Old Feb 18, 2008 | 10:51 AM
Relic1's Avatar
if there is oil in the cap then it's the bearing.
if not, then it could still be the bearing...
cap/rotor is not much $$.
Old Feb 18, 2008 | 11:40 AM
b.d.racing's Avatar
Default Re: (Relic1)
There is no oil in the cap and the sound comes and goes. Its mostly there during cold starts and goes away as it heats up or at least dulls in noise. I'm going to pull it apart tonight and hopefully it needs just the rotor but who knows.
Old Feb 18, 2008 | 01:13 PM
Relic1's Avatar
sounds like the bearing may be starting to go.
it has about 90-100k on it? (typical life span)
Old Feb 18, 2008 | 01:31 PM
b.d.racing's Avatar
It has 160k. Got the car 3k miles ago so I don't know if its the original one.
Old Feb 25, 2008 | 04:34 PM
Avenged7x's Avatar
Default Re: (b.d.racing)
I've got the same problem. Update us if you fix the problem. I know my rotor is bad so i plan on replacing that along with re adjusting my valves which is pass due even though i don't think this is contributing to the sound, but either way ill let you know if i find anything this week.
Old Feb 27, 2008 | 06:42 PM
b.d.racing's Avatar
Default Re: (Avenged7x)
I replaced the whole distributor and now its fine, no noise. I looked closer under the cap and saw the infamous red dust. I knew it was the bearings after that.
Old Mar 4, 2008 | 04:44 PM
orlandofast1's Avatar
Can you call me I am interested in your car 321-543-3858
durfeec
Apr 19, 2009 04:37 PM
airek
Jan 12, 2007 07:39 AM
bleedblue94
Jan 7, 2006 10:08 PM
See Are X
Dec 22, 2002 01:16 PM
Phat Corolla
Jan 29, 2002 06:48 AM
