p06 vtec conversion problem...
Old Feb 11, 2008 | 09:53 PM
teamitr's Avatar
Default p06 vtec conversion problem...
I did the conversion but when vtec kicks I get a check engine light (code 21)
vtec will last till the end of the shift but in the next gear there is no more vtec so what i do is turn on and off the car and the check engine light come off and i'll have vtec for one more pull...
Now vtec is set at like 6300 I did not have a reusable chip so i had to use one that was preprogramed that i had laying around...
I have used another ecu and it works fine with it...
so what component could I have burnt or be bad?
Old Mar 2, 2008 | 08:30 PM
JDMInteg96's Avatar
Default Re: p06 vtec conversion problem... (teamitr)
i had the same problem bro.. I only cracked vtec a couple times.. but once my car warmd up the next day.. it threw a code 21..My ecu isnt burnt or anything.. .. Did you figure out why its doing that?
01em2slvr
Honda Civic (2001 - 2005)
Nov 11, 2009 12:43 PM
CTR_B
Mar 20, 2008 10:21 PM
MiamiEgGSr
Feb 9, 2008 06:24 AM
tuckin15s_8315
Sep 28, 2005 09:35 PM
