Jumpy Rev counter
Old Feb 8, 2008 | 04:45 PM
mystic-s's Avatar
Default Jumpy Rev counter
i have a 96 itr and when ever the car reaches around 4000rpm or more the needle just starts jumping around and if i hit vtec it jumps to past 10,000 and stays there now it doesnt do this all the time but most of it and when i does do it the car feels like its holding back as if it thinks its hitting the rev limiter any ideas what this could be
Old Feb 8, 2008 | 04:52 PM
sorrule's Avatar
i'm not sure what it is exactly, maybe the crank position sensor. but I got a new dizzy it it fixed the problem for me. throwing any codes
Old Feb 8, 2008 | 05:12 PM
dansred2000si's Avatar
Default Re: (sorrule)
probably the coil in the dizzy, that fixed my problem today!!!! or a bad ground???
Old Feb 9, 2008 | 04:02 AM
mmuller's Avatar
Mad Scientist
Default Re: (dansred2000si)
check the wires going to your igniter
Old Feb 11, 2008 | 09:45 AM
mystic-s's Avatar
yeah i will take a look at the dizzy its a strange problem to have, cause it effects the performance a good bit
Old Feb 11, 2008 | 05:24 PM
ricearoni56's Avatar
Default Re: Jumpy Rev counter (mystic-s)
I had a similar problem with the speed sensor. When I replaced the sensor the speedo did the same thing especially at vtec. It turned out to be a fuse. It might be worth checking?
Old Feb 11, 2008 | 10:46 PM
DELTEGRA's Avatar
I would say in the dizzy for sure... My guess is the igniter.
Old Feb 13, 2008 | 03:36 PM
mystic-s's Avatar
fuse where was this fuse
Old Feb 19, 2008 | 12:37 PM
PI$TOL's Avatar
* B A N N E D *
PROB THE IGNITER. IT HAPPENED TO ME.
Old Feb 19, 2008 | 05:06 PM
JWhonda_ride's Avatar
Default Re: (PI$TOL)
def. something with the distributer, maybe something as simple as bad plug wires that are arcing? it was happening on my 88 teg (winter beater) ever so often and i put some new plug wires on and it fixed it. GL
Leandro Peņa
Honda Civic (2001 - 2005)
Sep 26, 2018 08:32 AM
DC2man
Mar 3, 2008 07:01 PM
KillaB18
Jan 14, 2004 07:22 PM
Mike95lude
Feb 18, 2002 09:50 PM
