thinking bout running e85 need advice
Old Feb 7, 2008 | 04:17 AM
T9U4ReBgO's Avatar
Default thinking bout running e85 need advice
ok I hear u need a 255 at least and bigger injectors...I have 580 now on a stock b20 how much bigger would I need to go..also what kinda power gains and what are some pros and cons....already search just trying to get more opponions thanks
Old Feb 7, 2008 | 08:13 AM
T9U4ReBgO's Avatar
Default Re: thinking bout running e85 need advice (T9U4ReBgO)
bump???
Old Feb 7, 2008 | 09:22 AM
RC000E's Avatar
You need about 30% more fuel ROUGHLY, so you can figure out what you need.
Old Feb 7, 2008 | 09:42 AM
rorik's Avatar
I just want to know, how the do you pronounce your screen name?
If you want people's opinions on sizing, you should should probably give a little more info.
Old Feb 7, 2008 | 10:18 AM
T9U4ReBgO's Avatar
Default Re: (rorik)
LOL my sn? Its just the word turbo with 94 eg inbetween the letters...my setup is stock b20 with sc34 log mani 255 walbro and 580 injectors...
Old Feb 7, 2008 | 12:56 PM
Schister66's Avatar
Man U FTW
As was previously stated, you need about 30% more fuel than a conventional gasoline setup. If you need help picking the correct size injector, just use 6cc of injector per whp. On E85, you need 7.8cc per whp.
Old Feb 7, 2008 | 08:55 PM
RC000E's Avatar
Default Re: (Schister66)
3000cc injectors for 500whp... ? You forgot the part about dividing by the number of cylinders....can't forget that.
Old Feb 7, 2008 | 08:57 PM
T9U4ReBgO's Avatar
also what plugs would I run with E85
Old Feb 7, 2008 | 08:58 PM
RC000E's Avatar
Default Re: (T9U4ReBgO)
I'm runnin standard NGK's....number 6's
Old Feb 7, 2008 | 10:07 PM
Schister66's Avatar
Man U FTW
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">3000cc injectors for 500whp... ? You forgot the part about dividing by the number of cylinders....can't forget that.</TD></TR></TABLE>
I thought that portion of it was a given...you need 3000cc of injector for the whole engine, then you divide by the number of cylinders...in our case, 4
Old Feb 9, 2008 | 12:31 AM
RC000E's Avatar
There's no such thing as a given on these forums...hahahaha...you know that. If there were things that were a given just think how many less threads there'd be about ebay manifolds....lol.
Old Feb 9, 2008 | 03:25 AM
T9U4ReBgO's Avatar
HAHA can u give me the exact part number on those plugs??? Thanks
Old Feb 9, 2008 | 06:08 AM
egsir2's Avatar
Dont you need to upgrade all your fuel lines also as E85 has way more corrosive properties then regular petrol.
b20btegg
Oct 5, 2009 06:59 PM
slowhitEJ1
Aug 19, 2009 09:37 AM
slowtegkauai
Mar 31, 2008 10:38 PM
granada sol
Jan 29, 2007 04:57 PM
builtB20turbo
Aug 26, 2003 12:39 PM
