D16y8 CamShaft TDC
Old Feb 3, 2008 | 04:32 AM
maddog20's Avatar
Default D16y8 CamShaft TDC
I replaced the HG on my Y8 and I have a timing question.
I thought the timing marks on the cam pulley are supposed to line up to the mating surface of the valve cover? If I use the timing pointers on the plastic cover it the cam is slightly advanced?
which should i use?
Old Feb 3, 2008 | 07:59 AM
z6hatchboy's Avatar
Default Re: D16y8 CamShaft TDC (maddog20)
on the cam gear there is 2 marks that are horzontal (like its cutting across it) with a "up" marke centered above it on the top of the gear. Then you have that odd ball mark in the lower left corner (same as the other 2 just in the lower left), line this is with one up with the one on the plastic cover behind the gear and the cam will be tdc.
blacktibby07
May 8, 2011 09:46 AM
ef-hatchcrap
Jan 25, 2008 12:45 PM
HybridRacer69
Nov 9, 2007 03:10 PM
97grnrs
May 10, 2007 03:25 PM
civic dx
Apr 1, 2003 05:50 PM
