fixing timing with adjustable cam gear??
Old May 6, 2007 | 06:38 PM
97grnrs's Avatar
Default fixing timing with adjustable cam gear??
im putting an a6 head on a b7 block.. i do believe when i did it before the timing belt was off by a tooth so i had to pick one way or the other to get the cam to line up.. i dont want this to happen again so im getting an adjustable cam gear but the question is how do i set it..? do i line up the marks with the timing cover marks like normal then loosen the cam gear bolts and rotate the inside? which way would it go? advance or retard?
Old May 10, 2007 | 03:25 PM
97grnrs's Avatar
Default Re: fixing timing with adjustable cam gear?? (97grnrs)
up
Ef4doorwagon
13
May 17, 2014 06:09 PM
ef-hatchcrap
Jan 25, 2008 12:45 PM
d15maverick
May 3, 2004 09:14 PM
Ignitecivic
Mar 15, 2002 12:32 PM
