Ignition questions for 500+hp
Old Jan 25, 2008 | 12:36 PM
Mr. Em1's Avatar
Default Ignition questions for 500+hp
Hey all this is the last thing i need some information on for my setup. Ignition. I wanted to know what you 500 plus hp guys are using. I have seen some people running stock but i would prefer to have something that will provide a more reliable spark in the higher boost/ revolution area (20+lbs and up to 9k)
thanks for the input in advance i appreciate the help
Also how cold of a plug are you guys using in the 500 to 650 hp range?
Modified by Mr. Em1 at 12:29 AM 1/26/2008
Old Jan 25, 2008 | 12:51 PM
SwappedTURBOegg's Avatar
500+ so 500 and 900? what actual number you talking here? i made 500 with stock ignition and revved to 9700 no problem.28 psi too.
900hp you're going to want to upgrade ignition.
Old Jan 25, 2008 | 12:59 PM
2FastxEg's Avatar
contact tony over at T1, they have a CBR coil on plug set up that would work really well in your situation.
Old Jan 25, 2008 | 01:33 PM
Mr. Em1's Avatar
yeah i was reading through related threads and the M+ w Pro 10 i think was the one that i was considering but i am shootin anywhere from 500-650whp. i just want it to be on safe side
Old Jan 25, 2008 | 02:58 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Mr. Em1)
m and w works, and for some reason msd works fine on my car, i dont know, everyone else hates msd. i dont have issues with it.
Old Jan 25, 2008 | 03:02 PM
Mr. Em1's Avatar
yeah it seems that msd can be hit or miss depending on msd you are running. I've has few friends run the 6a and 6al and have had nothing but problems. Boostedcivicsir, what msd setup are you currently running
Old Jan 25, 2008 | 04:19 PM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FastxEg &raquo;</TD></TR><TR><TD CLASS="quote">contact tony over at T1, they have a CBR coil on plug set up that would work really well in your situation. </TD></TR></TABLE>
Thats kinda a overkill dont you think for only 500-650WHP. Any ignition system will work for that much power. I've had my MSD 7AL2 for more than 10 years and no problems.
Old Jan 25, 2008 | 04:46 PM
Mr. Badwrench
the same 6AL, blaster ss, external coil cap and wires i had 6 years ago.
last setup used a 2 step for launch control.
Old Jan 25, 2008 | 08:17 PM
jjspec's Avatar
Default Re: (boostedcivicsir)
I use a MSD Digital 6 with a MSD HVC coil
Old Jan 25, 2008 | 08:36 PM
miller's Avatar
Default Re: (jjspec)
if you are shooting for 500-600, stock ignition will be fine. I have tuned alot of cars past 650 with stock igntion. Stock honda wire, stock distributor.
Old Jan 25, 2008 | 10:34 PM
2FastxEg's Avatar
Yeah, you are right, its a lil overkill, but still will work optimally. I mean, if this is the last piece to the puzzle, than i would go this route and get it done right the first time. I have had issues with MSD too. It would work fine for awhile, and then the coil goes bad. And this has happened on a few cars all ready, even on a few all motor cars too. Ever since i used the coil on plug, i never had to worry about ignition problems again. Spend a few extra dollars and call it a day ! plus, cant go wrong with the proven parts from T1 race development and great customer service that they provide.
Old Jan 26, 2008 | 08:33 AM
Mr. Em1's Avatar
well idk if if the stock ignition will be fine i rather spend my money on different parts of the car then. I guess I just go with a new honda dizzy and new wires
Old Jan 26, 2008 | 08:35 AM
B18c1turboedEK's Avatar
I had Msd 6a until 720hp, then the car broke up really bad so i switched it out!
Old Jan 26, 2008 | 10:24 AM
dester223's Avatar
Default Re: (B18c1turboedEK)
M&W FTW
Old Jan 26, 2008 | 09:30 PM
laosonick's Avatar
i made 517 and im on stock ignition
Aesthetic Gains
Sep 21, 2012 04:07 PM
extremeracer
Engine Management and Tuning
May 7, 2012 10:59 PM
Turbo-LS
Sep 17, 2006 12:40 PM
SIK IN DA HED
Nov 23, 2002 07:05 AM
uneekcrx
Apr 19, 2002 07:32 PM
