ctr cams into a gsr head????
ok i did a search and came up with nothing...so heres my question. when i put my ctr cams into my 94 gsr is there anything i should be aware of or is it a direct bolt in??? like will the gsr cam gears work on the ctr cams etc....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRD^sam »</TD></TR><TR><TD CLASS="quote">i would recommend you getting atleast itr valve train</TD></TR></TABLE>
Springs and retainers only or valves too?? I'm thinking might as well replace the valves when you are in there right??? I'm assuming an upgrade would help too...Sk2
yeah i was thinking that also
The valvetrain is fine as long as you keep the stock GSR redline, But you should really get a tune. I used only a CTR intake cam and blox intake mani and I/H/E and before my tune I was running extremly LEAN. Instead of running around 14.7:1 it was around 16:1. We also set WOT at around 13.1:1 the car and VTEC was much smoother afterwords and had a stronger mid range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heavy D »</TD></TR><TR><TD CLASS="quote">if it does work tell me about it. i would like to know how it went?
ill be taking plenty of pics and documenting the whole thing and posting it
ok i will share my setup with you guys. 95 gsr with ctr intake cam, skunk2 manifold, ebay 4-21 header sucks, bosal brospeed exhaust. i got it tuned and made 179.6 hp. went to the track and ran a 14.5 flat. could go faster if i had a nice header.
nope kept my stock ones just droped in the cam. i would show you guys the graph but my scanner is messed up ill take a pic of it later to prove it with my time slip. all i need is a better header and some better piping and ill be happy. this wasnt posible without xonocron and my brothers help.
