resurface or no?
Old Jan 21, 2008 | 05:47 PM
JScott3d's Avatar
Default resurface or no?
I picked up a head from a friend and he had it sitting on his bench. When I went to get it he slid it a little and it scratch the surface. There is a scratch starting from the 3 cyl to the outside edge. Will it be ok or will it need to be resurfaced? If it does need resurfaced how do I pull the intake and exhaust studs?
Old Jan 21, 2008 | 06:37 PM
so lazy's Avatar
Default Re: resurface or no? (JScott3d)
get it resurfaced... as for the studs.. EASY... just take 2 nuts that fit on the stud and put one in backwards and one in right and tighen it down using a wrench to hold one end and socket to tighten then just loosen..
Old Jan 21, 2008 | 10:24 PM
HEAD's Avatar
Default Re: resurface or no? (so lazy)
you don't need to pull any studs off to mill the head.
Old Jan 22, 2008 | 07:37 AM
CerealKiller's Avatar
Default Re: resurface or no? (HEAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HEAD &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to pull any studs off to mill the head.</TD></TR></TABLE>
x2, take it to local shop.
Old Jan 22, 2008 | 02:07 PM
so lazy's Avatar
sorry didn't read his post correctly.. it was freaking COLD! lol.. but x3 you do not need to take your studs out.. just exhuast manifold and intake manifold.
B18C_EJ8
Oct 29, 2007 04:33 PM
skiracer8148
11
Aug 14, 2007 07:59 PM
civicb18Tkid
May 3, 2007 07:30 AM
the.hamburglar
Nov 12, 2005 07:32 PM
D
Jan 8, 2004 04:01 PM
