DA brakes building pressure
Old Jan 21, 2008 | 04:35 PM
da9stalker's Avatar
Default DA brakes building pressure
O.K. I am stumped. My brakes start to stick when i've been driving my car 20 minutes or so. so bad to where i have to pull over and open a brake bleader to release the pressure. ive blead the entire system more than once, and i've replaced the master cyl, and replaced rubber lines with braided ones. still no fix. please no flamming or "your and idiot" posts I need help, not critisism thank you for any help. my car is a 1990 integra gs without abs
Old Jan 21, 2008 | 04:40 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: DA brakes building pressure (da9stalker)
Did you adjust the rod in the booster or master cylinder? When did the problem first start?
Old Jan 21, 2008 | 04:52 PM
da9stalker's Avatar
Default Re: DA brakes building pressure (Dogginator)
no i didn,t adjust the booster rod, I'll try that in the morning. It seems like the more the engine compartment warms up the brakes start to progressivly stick
Old Jan 21, 2008 | 05:04 PM
Dogginator's Avatar
Daisy... Daisy...
Does the pedal consistently come back the whole way?
Old Jan 21, 2008 | 05:11 PM
da9stalker's Avatar
yes, the pedal always comes back. normaly there is about an inch or two of pedal travel before the brakes start to engage. but when they build pressure, there is no travel, you can feel instant engagement when the pedal is pressed. actualy, you can feel them sticking when you let off of the gas pedal
Old Jan 21, 2008 | 05:15 PM
Dogginator's Avatar
Daisy... Daisy...
I would bet on the adjustment rod in that case. Do you have a Helm manual?
Old Jan 21, 2008 | 05:17 PM
da9stalker's Avatar
sure dont
Old Jan 21, 2008 | 05:37 PM
Dogginator's Avatar
Daisy... Daisy...
Examine my signature.
darksands
Suspension & Brakes
Jun 25, 2013 09:41 PM
1sikhatch
Dec 7, 2009 04:18 AM
snuzey671
17
Sep 23, 2008 02:20 AM
91_shoebox_Si
Mar 2, 2008 06:23 PM
jasonb
Oct 10, 2002 06:32 AM
