brake problems
Old Feb 26, 2008 | 09:20 AM
91_shoebox_Si's Avatar
Default brake problems
a few days ago my brakes started acting up on me. when i first apply pressure to the pedal it sinks to the floor and only the drivers side caliper engadges. if i pump the brakes, the pressure builds and both brakes work fine but they lose pressure very quickly. ive checked the calipers and both seem to be in working order and ive also bleed the brake lines to make sure there was no air. fluid doesn't seem to be leaking from anywhere, i dont see any spots on the ground. any ideas on what this could be? if its the master cylinder, how difficult is that to replace?
any help would be awesome.
thanks guys...
Old Feb 26, 2008 | 11:58 AM
thabao's Avatar
Default Re: brake problems (91_shoebox_Si)
i think it could be the master cylinder, i had the same probleom on my van. it's called like sponge pedal haha. but i'm not sure how hard it is to fix, i'm guessing moderatly difficult, not to hard but might encounter other issues.
Old Mar 1, 2008 | 08:18 PM
HennessyLane's Avatar
Do you have ABS if you do it the ABS system
Old Mar 2, 2008 | 12:05 PM
JGAccorn's Avatar
The primary and possibly secondary cup seal in your master cylinder is leaking internally. When the seal leaks it bypasses fluid inside your cylinder, that's why you have no leaks. You'll have to replace the master cyl.
Old Mar 2, 2008 | 06:23 PM
Default Re: brake problems (JGAccorn)
thanks guys. replaced the master cylinder and everything is back to normal. thanks for the help.
SubwayH23
Jun 23, 2018 03:13 AM
darksands
Suspension & Brakes
Jun 25, 2013 09:41 PM
Peruviann83
Dec 31, 2008 08:59 AM
digitalayon
Mar 13, 2005 02:48 AM
Integraxnyc
Apr 13, 2004 02:19 PM
