b18c1
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb »</TD></TR><TR><TD CLASS="quote">I was wondering, I know with the p72 ecu u have to wire the iab, and knock sensor up. But if u chip ur p28 will u have to do them things?</TD></TR></TABLE>
No. The P28 has no input/outputs for the IAB or knock. So you can leave those out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb »</TD></TR><TR><TD CLASS="quote">Alright and the engine will not throw any codes using the chipped p28?</TD></TR></TABLE>
The ECU throws codes. Not the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">u should change the stock gsr IM if ur gonna use a p28</TD></TR></TABLE>
Or just undo the vacuum line for the butterflies so they're always open.
From what i got so far i got the a20 pin switch to the a17 pin on my ecu thats done, then i cut my knock sensor off the gsr harness and add to it my z6 harness on plug d for the shock tower, then i add a wire from plug d through the firewall to d3 on the ecu plug .. Is that all ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb »</TD></TR><TR><TD CLASS="quote">From what i got so far i got the a20 pin switch to the a17 pin on my ecu thats done, then i cut my knock sensor off the gsr harness and add to it my z6 harness on plug d for the shock tower, then i add a wire from plug d through the firewall to d3 on the ecu plug .. Is that all ?</TD></TR></TABLE>
Yeah. That sounds like all the wiring mods. However, why did you have to switch the A20 pin to the A17 pin? Your car allready came wired with VTEC and with a 2 wire IAC.
I believe the A20 to A17 pin switch is for 96-00 non ex/si models that have the 3 wire IAC, IIRC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb »</TD></TR><TR><TD CLASS="quote">switched the a20 pin cause ya dont use it on the gsr motor and put it in a17 for the iab.</TD></TR></TABLE>
What does the A20 correspond to? You dont have an IAB function on the P28, though. You might as well have just left that alone....
MOVE OVER
Sep 6, 2007 08:59 AM
streetracerof06
10
Dec 29, 2005 06:14 PM
