s300 matrix help
Old Jan 13, 2008 | 07:01 AM
laziebun's Avatar
Default s300 matrix help
well i checking out my datalog, and notice somthing that seem wired to me. Notice how the boost is at 12.1 psi and on the matrix its showing me that im at column 12 and 13 which is only 5.8 and 7.8psi....any one might have a clue on this one???
Old Jan 13, 2008 | 08:01 AM
TheWickedOne's Avatar
Default Re: s300 matrix help (laziebun)
Can you verify if your Sensor Setup for Map is psi, or "/psi ?
go th View/options/sensors/map and see what its displaying in Units..
Let us know.
Old Jan 13, 2008 | 08:17 AM
laziebun's Avatar
Default Re: s300 matrix help (TheWickedOne)
its in "/psi...............
Old Jan 13, 2008 | 09:08 AM
DaveF's Avatar
can you select a different sensor
oem
gm 1 bar, 2 bar, or 3 bar
5 bar
Old Jan 13, 2008 | 09:26 AM
dreadcivicturbo's Avatar
which map sensor do u have and which one u have selected in smanager....make sure the voltage of both matches.
Old Jan 13, 2008 | 09:31 AM
laziebun's Avatar
Default Re: (dreadcivicturbo)
i have an AEM 3.5 bar, thats what i have selected in Smanager. What do you mean both the senor and what else? The AEM one is a preselected one that HONDATA had in there lists of map.
Old Jan 13, 2008 | 10:20 AM
Drag_S14's Avatar
Default Re: (laziebun)
Uh, what the hell is going on with the vacuum numbers? It goes from less to more vacuum from columns 1 to 9, then jumps to 0.5psi boost. It looks like there is something majorly wrong going on with your map...
You may want to post the map and the datalog so we can all look at it. If you need, I can host them for you, just email them to me at blakebonkofsky@geektuned.com.
Old Jan 13, 2008 | 10:33 AM
Default Re: (Drag_S14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_S14 &raquo;</TD></TR><TR><TD CLASS="quote">Uh, what the hell is going on with the vacuum numbers? It goes from less to more vacuum from columns 1 to 9, then jumps to 0.5psi boost. It looks like there is something majorly wrong going on with your map...
He has vacum setup as absolute, it should be set to atmospheric.
Old Jan 13, 2008 | 10:53 AM
laziebun's Avatar
Default Re: (TheWickedOne)
Sent Thanks
Old Jan 13, 2008 | 11:13 AM
laziebun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWickedOne &raquo;</TD></TR><TR><TD CLASS="quote">
He has vacum setup as absolute, it should be set to atmospheric. </TD></TR></TABLE>
Yup thats was the probelm with that (thanks), but still having the issue with 12.1psi hanging around 12 and 13 column.
Old Jan 13, 2008 | 12:28 PM
Send the map over.
Old Jan 13, 2008 | 12:41 PM
laziebun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWickedOne &raquo;</TD></TR><TR><TD CLASS="quote">Send the map over.</TD></TR></TABLE>
I'm not sure what you mean by that.
Old Jan 13, 2008 | 12:42 PM
I sent you a pm.
Old Jan 13, 2008 | 01:03 PM
laziebun's Avatar
pm not recieved
Old Jan 13, 2008 | 02:10 PM
At the point, not trying to sound like an a$$, but you really need to get your car professionally tuned. Your map is still wacked out like it was when you initially posted the map way back. I have no issues on my end viewing my own Maps and datalogs, I'm sorry to say but you should not be boosting on this map..
As for your Map sensor not sync'n to Table vs display. I suggest you contact Hondata and ask them on their support website, or go see a tuner for troubleshooting. Settings etc.. look ok.
Old Jan 13, 2008 | 05:41 PM
turbotypeR@SPEC's Avatar
25 Year Member
under map in parameters, there is a voltage to pressure conversion. what do you have the scalar and offset at? i looked mine up and they were 862.4 on the scalar and -431 for offset
Old Jan 13, 2008 | 07:19 PM
Drag_S14's Avatar
I hosted the map and log for him:
http://www.geektuned.com/Temp/laziebun/
Old Jan 13, 2008 | 07:20 PM
Drag_S14's Avatar
The only thing I can find, is that the values do line up when selected secondary maps, however, the map has these maps disabled, so I'm not sure why this is happening.
Old Jan 13, 2008 | 07:25 PM
laziebun's Avatar
Default Re: s300 matrix help (turbotypeR@SPEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC &raquo;</TD></TR><TR><TD CLASS="quote">under map in parameters, there is a voltage to pressure conversion. what do you have the scalar and offset at? i looked mine up and they were 862.4 on the scalar and -431 for offset</TD></TR></TABLE>
Yup setup just like yours
Old Jan 13, 2008 | 07:41 PM
seen4ever's Avatar
what's up with the map scaler going to 16psi only in cell 24? normally that would be like 60psi under 5bar mode. Looks like you did the add load index and datalog is confused, aka its maping to the standard index versus your created indexes.
aka, if you had the standard load index, column 12 & 13 would be between 7.8psi and 12psi.
Old Jan 14, 2008 | 04:32 AM
25 Year Member
Default Re: s300 matrix help (seen4ever)
just post this on hondata's forum. they should be able to take care of it right away
Old Jan 14, 2008 | 04:53 AM
laziebun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_S14 &raquo;</TD></TR><TR><TD CLASS="quote">The only thing I can find, is that the values do line up when selected secondary maps, however, the map has these maps disabled, so I'm not sure why this is happening.</TD></TR></TABLE>
seen4ever that the funny thing it works in secondary table....
Old Jan 14, 2008 | 04:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC &raquo;</TD></TR><TR><TD CLASS="quote">just post this on hondata's forum. they should be able to take care of it right away</TD></TR></TABLE>
Potential bug/discrepancy, or your map is so jacked up its melting the daughter board
insaneconceptz
Mar 4, 2009 05:35 AM
1QwIkEf
May 20, 2008 06:07 AM
LSEGHATCH
Oct 24, 2005 10:12 AM
Beer
Jun 19, 2002 11:44 PM
Pro-Lude
Aug 29, 2001 04:26 AM
