First time racer
Old Jan 11, 2008 | 09:40 PM
GSE980's Avatar
Default First time racer
I went to the Street legal event in Diego 1/8 mile the only experience I have is in the streets of philly no track exp.
I ran 5 times
my setup is rebuilt low comp for future turbo
del sol
GSR
IHE
upgraded fuel system
new 205 tires on 15' rotas
my best run was
RT---------1.481
60ft--------2.491
MPH--------61.72
ET----------10.584
I was launching about 4k on my launch control. I lost a lot of RPM from 1-2 and third was so hard to hit at 8k...
How did I do what should I improve on for this setup
Old Jan 11, 2008 | 10:05 PM
ExospeedAMcrx's Avatar
Default Re: First time racer (GSE980)
Good to see you hitting up the track down there.
From your time slip, it show you can get better times through better 60fts. 2.4 is pretty high there. Maybe on avg, at best launch on street tires you can get 2.0-2.1, thats an easy gain of .3sec
And if you ran slicks, usually you can get into the 1.7-1.8 range and lower your ET by about .7 sec. That would get you down to the 9.80s.
You can usually also get more consistent times with slicks rather than street tires.
Old Jan 12, 2008 | 05:36 PM
SpeedSceneScott's Avatar
Default Re: First time racer (ExospeedAMcrx)
Glad to see a fresh racer joining the ranks. You are off to a good start, so just keep practising and getting seat time. You will have a lot of fun as long as you keep going.
Old Jan 13, 2008 | 12:00 PM
GSE980's Avatar
i think Im losing third gear...
Every time im in high rpms it grinds no matter how far i PUSH THE CLUTCH in all other gears work fine....
I missed third like three times I think Im might switch to a b16 tranny
Old Jan 14, 2008 | 11:05 AM
Civic89stdB16's Avatar
Default Re: (GSE980)
u need new syncros. check out gearspeed for them.
RyanEJ8
Mar 7, 2006 05:06 PM
slowsleeper
Oct 20, 2004 02:55 AM
Nextelbuddy
Jun 19, 2004 09:32 PM
HX_Guy
Jan 24, 2002 12:10 PM
HX_Guy
Oct 11, 2001 07:25 AM
