vtec pressure switch
Old Jan 12, 2008 | 06:54 AM
skoodles2k6's Avatar
Default vtec pressure switch
well im just about done with my swap and was wiring in my obd0-obd1 harness and started looking my CTR head doesnt have a vtec pressure switch. as stated here
http://www.ff-squad.com/tech/sensors/vtps.jpg
do i just not hook up the wires? and you can disable it to look for it in crome?
Modified by skoodles2k6 at 10:16 AM 1/12/2008
Old Jan 12, 2008 | 09:20 AM
4g hatch's Avatar
Default Re: vtec pressure switch (skoodles2k6)
jdm heads do not have the pressure switch. what ecu are you running. you can disable it or at the ecu loop the pressure switch wire to the vtec solonoid so it wont throw a code
Old Jan 12, 2008 | 10:31 AM
Default Re: vtec pressure switch (4g hatch)
socketed p28 with datalogging gonna be tuned on crome pro.
Old Jan 12, 2008 | 11:59 PM
mtber's Avatar
Old Jan 13, 2008 | 04:34 PM
Default Re: vtec pressure switch (mtber)
thanks ill look into it.
Old Feb 9, 2008 | 12:46 PM
rmiller's Avatar
Would it be better to remove the bolt and add in a VTEC pressure switch and run a wire back to the ECU?
Old Feb 9, 2008 | 02:41 PM
Brick Top's Avatar
Default Re: vtec pressure switch (rmiller)
^^with the OP case, he's better off disabling it and not wasting the time.
Old Apr 11, 2008 | 09:25 PM
4potnick's Avatar
Default Re: vtec pressure switch (Brick Top)
I am having problems with my pressure switch. I think I am going to disable it.
Old Apr 11, 2008 | 09:58 PM
turbod da's Avatar
i always wanted to know this!
good info
Old Apr 14, 2008 | 07:29 PM
Default Re: vtec pressure switch (turbod da)
well with a chipped ecu you dont have to do that wire jumper. can disable it through the program. is what my tuner said.
Delphince
Engine Management and Tuning
23
Jun 8, 2018 05:18 AM
Freya Franco
Dec 13, 2017 10:49 PM
iNERtIA
Apr 3, 2006 09:42 PM
tinkerbell
Jan 1, 2005 08:00 PM
VXdreamer
Mar 2, 2003 12:49 PM
