engine light on h22 vtec not working
Is there any way to diagnose why engine light is on. oxy sensors are good all wires connected v-tec not working would that cause the problem please help
the oil is fine I thaught that would be the problem with the v tec also but i drained and added oil to make sure it was correct, maybe vtec solinoid bad? do you know of a way to get the code for a 95? ive been looking for a diagnostic comp but cant find one thanks for reply
there is a two wire plug behind the center console/radio. jump the two wires together with a paper clip. Then turn your ignition switch on, your check engine light will flash, telling you which code is the problem.
long flash means count 10's, short flash means count one's
so, two long flash, then two short flash means code 22
four long flash, one short flash means 41
yes, it will repeat over and over. if it keeps repeating the same #, you only have one code. sometimes there are more than one. it will be a two digit #.
post it up on here. i have almost all of them memorized.
or search for trouble code threads, i am sure they are on here
codes
not sure if it's 100% complete, but these are the most common issues
http://www.hondaprelude.to/art....html
ty good information will try this weekend because car is at different location but i will definately let you know and ty for link i will lok at it.
MAN!!!! Good Info!!!! Guess I should have told you i didnt have a lude but a 94 accord, took me a sec to find the plug but when i did, put in the paperclip, got code twenty two looked at link you gave me and code 22 vtec solenoid problem. Took solenoid off checked screen thats ok and oil flowing through good, looked down and i see this little black wire sticking out
? So i untaped vtec wires and nothing for black wire to connect to so it must be a ground!!!!! Then I ground the wire to the clamp on vtec solenoid, reset the ecu, and NO MORE ENGINE LIGHT AND VTEC AT 5000rpm WOOHOOO!!!!!!!! TY man for all the help!!! Just put rims on and bout to try to paint it myself will post pictures hopefully one day!!!!
Oh How much hp would you think i would get if i stroked it to 2.49? Trying to go N/A
anyone with h22 problems is welcome in prelude forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">Next Time post in the Honda Accord fourm.
Congrats on the Fix.</TD></TR></TABLE>
This guy that owns a race shop offering to sell me a ported and polished head for $600 he ordered it before he sold his race car and say he will give it to me real cheap. The head, eibach dual valve springs, titanium retainers, ferrera valves, high compression pistons he said it can handle 10,000 rpms does that mean my readline will increase without damaging valves or engine or will i have to do more. all that for $600
36Chitownrunnin
Jun 17, 2008 08:44 PM
