gsr code 22
Old Apr 27, 2004 | 07:53 PM
McNizzle's Avatar
Default gsr code 22
this is a repost (i also posted in the eg forum but i thought that maybe u teggy guys would be able to help out as well)
i have a 95civ coupe with a jdm b18c in it and ever since i had the swap done, the engine light has been on. When i tested it, the light gave 2 solid flashes and 2 quick flashes, which i believe is code 22 right? I searched on h-t about code 22 and figured out it was the vtec oil pressure switch. The thing i dont understand is that my vtec kicks in with no problem so i dont understand exactly what the problem is? Could it possibly be the ground, could it be dirty or what? I just thought that if i had code 22 that the vtec wouldnt even engage? any feedback would be great. Thanks in advance!
Old Apr 28, 2004 | 05:44 AM
maggsgsr's Avatar
Default Re: gsr code 22 (EjCiViC)
I had the same issue, after 3500 miles I didn't check the oil and she was 1 3/4 low and the cell code 22 came up.
I'm not a machanic but from what I've been told is:
1. Check your oil
2. clean the metal screen for the vtec selonoid
3. Oil pressue switch is disconnected or bad
4. ECU pins outs
Hope it helps.
36Chitownrunnin
Jun 17, 2008 08:44 PM
McNizzle
Apr 27, 2004 07:46 PM
endlesswinterco
Jan 10, 2004 01:26 PM
f1nal zeros
Aug 22, 2002 11:36 AM
typer_801
Mar 19, 2002 07:08 AM
