1990 Accord problem
Old Jan 5, 2008 | 12:05 PM
cb7tuned's Avatar
Default 1990 Accord problem
so my heater has been acting weird lately. Out of no where the heat just stopped working. the a/c and the fan are working just fine.
I checked all of the fuses and even changed out my thermostat, hoping that was the problem.
still no heat. what should be my next move?
what can i check next?
Old Jan 5, 2008 | 12:23 PM
cb9tuner's Avatar
Default Re: 1990 Accord problem (cb7tuned)
are you leaking any coolant? does the blower motor work? sounds to me like the heater core isnt working right , check to see if the little cable that opens the coolant passage to the heater core isnt damaged or pinched.
Old Jan 5, 2008 | 12:27 PM
cb7tuned's Avatar
Default Re: 1990 Accord problem (cb9tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb9tuner &raquo;</TD></TR><TR><TD CLASS="quote">are you leaking any coolant? does the blower motor work? sounds to me like the heater core isnt working right , check to see if the little cable that opens the coolant passage to the heater core isnt damaged or pinched.</TD></TR></TABLE>
no, i dont have any leaks.
like i said everything as far as the a/c and the blower are working fine.
where can i find that "little cable that might be pinched?"
Old Jan 5, 2008 | 12:33 PM
cb9tuner's Avatar
its where the heater hoses are at, follow the little coolant hoses that go the the fire wall, if you remove your intake and look straight down you can see a little hose going to a little box with a cable going to it if I had my camera ill take a pic but i dont hope it hepls
Old Jan 5, 2008 | 04:08 PM
cb7tuned's Avatar
BUMP
Old Jan 5, 2008 | 04:09 PM
cb7tuned's Avatar
BUMP
come on people i need all the help i can get.
thanks in advance
Old Jan 6, 2008 | 06:36 PM
F20B EK's Avatar
look under the dash and make shure the linkage is still all on track , or disconnect the hose on the head that goes to your heater core , hook a garden hose to it and see if water flows out of the head to make shure its not clogged
92eg6lsvtec
14
Feb 15, 2007 01:34 AM
hatch_
Dec 25, 2006 11:02 AM
hatch_
Jan 25, 2006 07:10 PM
md88hfcrx
10
Dec 20, 2005 01:08 PM
rdaggett
Aug 11, 2004 12:48 PM
