93 delsol with y7, question on mini me
Old Jan 2, 2008 | 03:50 PM
CruiserDan's Avatar
Default 93 delsol with y7, question on mini me
so i have a 93 del sol that was an auto to manual swap guy i bought it from put in a y7, i want to do a mini me what kind of ecu will i need and or any type of conversion harness. i know i can use either a z6 head or a y8 but im just really confused. i searched alot got some info but wondering if anyone could shed some light. the confusing part is the obd1 car with obd 2 engine
Old Jan 2, 2008 | 06:40 PM
CruiserDan's Avatar
Default Re: 93 delsol with y7, question on mini me (CruiserDan)
anyone?
Old Jan 3, 2008 | 11:16 AM
CruiserDan's Avatar
any help or advice would be greatly appreciated
Old Jan 3, 2008 | 11:38 AM
andoxviii's Avatar
Which ECU is in the vehicle currently?
Old Jan 3, 2008 | 11:40 AM
andoxviii's Avatar
https://honda-tech.com/zerothread?id=735196
This thread will help you a lot with this head-swap. It says you should use the y8 ecu.
Old Jan 3, 2008 | 02:10 PM
boost and bass's Avatar
get a y8 head, p28 ecu, obd1 conversion harness for the ecu
Old Jan 3, 2008 | 02:25 PM
Dasfinc's Avatar
Default Re: (boost and bass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost and bass &raquo;</TD></TR><TR><TD CLASS="quote">get a y8 head, p28 ecu, obd1 conversion harness for the ecu</TD></TR></TABLE>
That'd incorrect chief, P28 ECU is programmed for the Z6, unless he is getting it chipped for the Y8, no point.
You need a P2E, or P2P ECU *Whatever your car DOESN'T already have*
and yes, a Y8 head would be ideal, no conversion harness needed, but you will have to add wiring for Vtec *Fairly easy, you can do a search for "Wiring Vtec"
Old Jan 3, 2008 | 02:30 PM
slo_hatch's Avatar
Default Re: (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc &raquo;</TD></TR><TR><TD CLASS="quote">
and yes, a Y8 head would be ideal, no conversion harness needed, but you will have to add wiring for Vtec *Fairly easy, you can do a search for "Wiring Vtec"</TD></TR></TABLE>
x2 good info man.
Old Jan 3, 2008 | 03:54 PM
Dasfinc's Avatar
Default Re: (slo_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
x2 good info man.</TD></TR></TABLE>
I've been working on my Hybrid Mini-Me swap for months now, I'm learning more than I need to know on them...
D16Y8 head on a D15B8 Block, the head is decked to boot, Wicked high compression.
Old Jan 4, 2008 | 01:00 PM
CruiserDan's Avatar
ok so i need the ecu from the y8?
Old Jan 4, 2008 | 01:20 PM
Lasty K's Avatar
Default Re: (CruiserDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CruiserDan &raquo;</TD></TR><TR><TD CLASS="quote">ok so i need the ecu from the y8? </TD></TR></TABLE>
Old Jan 5, 2008 | 12:12 PM
CruiserDan's Avatar
Default Re: (Lasty K)
Godspeedmj
Apr 22, 2010 03:17 PM
boost and bass
Jan 4, 2008 02:52 PM
turnsignalandy
Apr 20, 2006 06:25 PM
Riceburner247
Jul 11, 2005 09:32 PM
Rydaddy
Nov 2, 2003 04:27 PM
