p 28 ecu question?
p 28 ecu question?
Hi i have a 99 dx with a d16y7, im building a d16y8 motor and was wondering if i can use my p28 ecu with the Y7 motor before i finish the y8 build. reason why is i have gauges to wire and wanna tap into the ecu conversion harness rather then cuttin up my honda harness.
Re: p 28 ecu question? (boost and bass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost and bass »</TD></TR><TR><TD CLASS="quote">Hi i have a 99 dx with a d16y7, im building a d16y8 motor and was wondering if i can use my p28 ecu with the Y7 motor before i finish the y8 build. reason why is i have gauges to wire and wanna tap into the ecu conversion harness rather then cuttin up my honda harness.</TD></TR></TABLE>
you will need the OBD2 to OBD1 jumper harness so you can use the p28 ecu (obd1) on the Y8 (odb2)
Re: (boost and bass)
hummm i need to think about this but i think there are a few things on a obd2 motor that a obd1 harness may not cover. do a search like im going to.
KiNGDEE206
04-14-2014 07:35 PM
bunnyx
04-30-2008 01:53 AM
CruiserDan
11
01-05-2008 12:12 PM
