EDM amber clock with no pigtail????????????
Old Jan 1, 2008 | 05:44 PM
jdmdohcek98's Avatar
Default EK EDM amber clock with no pigtail????????????
i recently picked up an edm amber clock for my EK from ebay but it didnt come with the pigtail is there any place i can buy the pigtail? or maybe i can use a plug from another ca?r any suggestions would help. also i kno you can rig it without the plug but i dont like rigging **** so please dont tell me it will still work thanks.
Modified by jdmdohcek98 at 6:14 PM 1/2/2008
Old Jan 2, 2008 | 11:21 AM
Default Re: EDM amber clock with no pigtail???????????? (jdmdohcek98)
Old Jan 2, 2008 | 12:59 PM
jus_spooln_wicha's Avatar
I take it you have an EK.. cuz my amber clock in my eg plugged right into the usdm harness in my dash.. jw
Old Jan 2, 2008 | 01:22 PM
BlueIntegraBoy's Avatar
NOFX might know if there's a similar plug that will work from a USDM car.
Old Jan 2, 2008 | 02:13 PM
Default Re: EDM amber clock with no pigtail???????????? (BlueIntegraBoy)
thanks ill try nofx...yes its an ek
Old Jan 5, 2008 | 09:16 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">NOFX might know if there's a similar plug that will work from a USDM car.</TD></TR></TABLE>
Might as well update this in the event anyone else ever searches and finds it.
I'm not aware of any plug on a USDM vehicle that matches the plug on the European clock.
Old Jan 5, 2008 | 10:46 PM
JimDCXC's Avatar
Default Re: EDM amber clock with no pigtail???????????? (NOFX)
I also got my clock with no harness but you dont need it, just pop the back of the clock off so you can easily get to the four pins and just hook up 4 wires directly to the pins. I chose to solder mine because there wasn't enough room for connectors. Each pin is labeled.
Old Jan 7, 2008 | 03:15 PM
Default Re: EDM amber clock with no pigtail???????????? (JimDCXC)
yea i know my buddy did it but i hate rigging stuff
Old May 21, 2008 | 10:44 AM
Memnoch's Avatar
Check the plug that is used to connect the window switches on the driver side of the interior, I believe the plugs are the same for the switch as for the clock. Keep us updated.. if it is then you can go to a junkyard and cut it out of another civic...
Old May 21, 2008 | 04:38 PM
Default Re: EDM amber clock with no pigtail???????????? (Memnoch)
good stuff man yes it works i happen to have 2 ek door harness and it plugs right up nice find bro
Old May 21, 2008 | 04:50 PM
pdiggitydogg's Avatar
coupe door switch plugs are big...
The only style plug that MAY fit, is that for the dimmer. Its the same number of wires, but may require some trimming to get it to fit.
Old May 21, 2008 | 05:55 PM
Default Re: (pdiggitydogg)
its a plug from the drivers side door harness. it works cause i have 2 at my house. now im not sure where the plug goes to on the door cause i havent got a chance to check but one of those plugs definitly works
Old May 21, 2008 | 08:52 PM
NOFX's Avatar
H-T White Ops
I really hope there's another plug on the car that can be used besides that. It would suck for people to go around ruining full power door conversions just for one measly plug for a clock.
I think the focus should stay on making sure you get one when you order the clock.
Perhaps someone can find the same plug elsewhere.
Old May 22, 2008 | 05:58 AM
I have a feeling this is the connector for the lock switch.
I agree: Lets not hack up door harnesses - there has to be something else....
Old May 22, 2008 | 11:56 AM
Memnoch's Avatar
It doesn't matter if you go to a junk yard and tear up a few plugs big deal, find me another solution that won't involve hacking some plug off of some electrical system that some pansy is gonna [freak]ing cry about, cause you won't..
Suck it up and be glad I found a solution for all the EDM clocks w/o piggytails...
Old May 22, 2008 | 09:09 PM
NOFX's Avatar
H-T White Ops
Default Re: (Memnoch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Memnoch &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't matter if you go to a junk yard and tear up a few plugs big deal, find me another solution that won't involve hacking some plug off of some electrical system that some pansy is gonna [freak]ing cry about, cause you won't..
Suck it up and be glad I found a solution for all the EDM clocks w/o piggytails...</TD></TR></TABLE>
I found a solution too.
I made sure mine came with a pigtail when I "bought" it.
There should also be other locations that plug is on the car besides power doors that are sought after. It just seems a shame to ruin $300 worth of parts.. because you want an orange clock.
Would you be against using a plug from another location?
Old May 23, 2008 | 07:58 PM
Memnoch's Avatar
Default Re: (NOFX)
No I'm just saying I'm pretty sure these plugs for the window buttons are the same through most honda/acura chassis, so I got a better deal on a clock that didn't have a piggy tail and I found a solution, its not like theres gonna be a edm clock craze and all the junkyard power window swaps are gonna be butchered.
Old May 27, 2008 | 06:34 PM
i agree with both try and get the edm clock with a pig tail or if not try to solder the wires but if its a must you kno where to find it like i said good find memnoch
dewey_civic
Oct 6, 2013 06:15 AM
DC2-ProdUcTiOnS
Feb 24, 2009 12:34 PM
jdmdohcek98
18
Apr 9, 2008 07:59 AM
SIRIUS
Sep 13, 2006 03:52 PM
jdmdohcek98
Aug 19, 2006 08:41 AM
