Making a B16A to a 1.9 liter
Old Jan 1, 2008 | 09:33 AM
TurboB16A300Hpteg's Avatar
Default Making a B16A to a 1.9 liter
what parts Exactly are needed to make a JdmB16A into a 1.9 liter is it what just ls crank n rods or sumthing to that aspect any maching needed?? or better off to just go to junk yard buy a Ls moter for 200 tear it down sleeve n build it?? mine b16 now is fully built and Darton sleeved which way would be cheaper
Old Jan 1, 2008 | 10:18 AM
turbociv910's Avatar
Default Re: Making a B16A to a 1.9 liter (TurboB16A300Hpteg)
lol.
cant understand you.
Old Jan 1, 2008 | 10:31 AM
b18_spoon's Avatar
I think I saw Dsport magazine's b16 turbo project @ 17--cc with an 84.5 mm bore.
If you just go with an LS crank and rods, it will basically be a short deck ls block. So
your definitely gonna need some sleeving to get the bore size bigger. I don't really follow up too much with magazine projects but from what I remember that b16 got really close to a 9 sec. time slip with the factory crank. My sec. gen. b16 w/ 10.4to1 on 10lbs. made 302 whp and 178ft.lbs.. My DA ran consistent 11.2's with A/C pulley still on there.
Old Jan 1, 2008 | 11:22 AM
Garage 808 Hatch's Avatar
to make a B16 a 1.9, you need, sleeved and bored out, and a deck plate to raise the deck height
Old Jan 1, 2008 | 11:36 AM
boosstboy's Avatar
Default Re: (Garage 808 Hatch)
if you go to 85 mm bore it would turn into a 1.8 a modification in crank stroke or deck plate would be needed to go bigger.
Old Jan 1, 2008 | 01:45 PM
gibsanez's Avatar
Default Re: (boosstboy)
B17 crank with extra thick sleeves and 86mm bore.
HatchMo
Jul 1, 2007 05:51 PM
myblackhatch
Oct 18, 2006 07:38 AM
CircuitFG
May 4, 2005 01:19 AM
wm5holla
May 6, 2003 09:27 AM
sean
Aug 8, 2002 07:48 AM
