clicking injectors?????
well guys i have a clickin noise on my d16z6
though it might be valve tap
got a valve adjustment
still clicks.....
sounds like its coming from my injectors???
anyone had this problem?? or know a solution???
thanks in advance!!
still clicks.....
thanks in advance!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Ty [EG6 »</TD></TR><TR><TD CLASS="quote">]well guys i have a clickin noise on my d16z6
still clicks.....
thanks in advance!!</TD></TR></TABLE>
are they dsm's? or bigger injectors? or just stock?
still clicks.....
they r stock
i jus swapped the z6 in the car... and its weird becuz the higher the rpm the louder it gets...
i have a different IM that ima swap on see if it fixes the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">let us know that fixs it.</TD></TR></TABLE>
i will
if it doesn't the idk wtf to do....
i will
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Ty [EG6 »</TD></TR><TR><TD CLASS="quote">]my idle is jus under 1000 rpm</TD></TR></TABLE>
Well that rules that out then.
Whens the last time you replaced your fuel filter? Run some injector cleaner thru your gastank anytime recently?
i jus swapped in the motor last night
it runs strong and pulls hard
jus a annoying clicking sound.
after i put on the other complete IM i'll see if the sound is still there
if so i guess its not the injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Ty [EG6 »</TD></TR><TR><TD CLASS="quote">]its throughout
it gets louder the higher the rpms</TD></TR></TABLE>
I would say swap out the injectors, see where that gets you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
I would say swap out the injectors, see where that gets you. </TD></TR></TABLE>
yeah i'll do that
yeah i'll do that
d3vilishSi
21
Feb 16, 2007 02:37 PM
