i dont know whats wrong help me out
Old Dec 30, 2007 | 07:44 AM
sin2o3's Avatar
* B A N N E D *
Default i dont know whats wrong help me out
alright the integra sounds bad and i dont know why every time i go to first or 2nd it makes a loud rattleling noise or when i step on the accelerator and sometimes it stalls out on purpose when goin to neutral at a complete stop goin into first ? any one know whats wrong let me know oh yeah the oil pan is blinkin red so im going to do the oil change but im not sure if thats the problem because it never rattled before
Old Dec 30, 2007 | 07:53 AM
whatan00b's Avatar
Default Re: i dont know whats wrong help me out (sin2o3)
First change that oil asap!
The rattle could be your heatshield on the cat other than that I'm not to sure but check that first.
Old Dec 30, 2007 | 07:58 AM
sin2o3's Avatar
* B A N N E D *
Default Re: i dont know whats wrong help me out (whatan00b)
alright after i change the oil ill check the cat and get back to u
Old Dec 30, 2007 | 08:00 AM
Blahblah718293's Avatar
i wouldnt start it again till that oil is done. but it could be low fuel pressure that causes you to stall when accelerating.
also, title your posts better.
Old Dec 30, 2007 | 08:09 AM
sin2o3's Avatar
* B A N N E D *
Default Re: i dont know whats wrong help me out (Blahblah718293)
u think the fuel filter has anythng to do with it i havent replaced it yet i have it in the car but i never put it in cuz i had a hard time to g et the bolt off but i just sprayed some more wd40 on it
Old Dec 30, 2007 | 08:36 AM
i think fix the oil then come back, cause i wouldnt even crank it at this point. even after you change the oil, if you had a light on you may want to hand crank it before you start it to prevent a dry start.
Old Jan 3, 2008 | 07:50 AM
PinoyDelSol's Avatar
* B A N N E D *
BTW you blew the motor.
Old Jan 3, 2008 | 08:03 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: i dont know whats wrong help me out (PinoyDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sin2o3 &raquo;</TD></TR><TR><TD CLASS="quote"> oh yeah the oil pan is blinkin red </TD></TR></TABLE>
Yeah, when your oil pan is blinking red you know she's done.
Old Jan 3, 2008 | 01:16 PM
sg's Avatar
sg
Default Re: i dont know whats wrong help me out (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, when your oil pan is blinking red you know she's done.</TD></TR></TABLE>
thats not always the case. i was lucky my oil light was blinking before(about 5,000mi ago). i pulled over and shut the car off. i was low on oil
heres a rule of thumb, if that happens check your oil, you probably need to put at least 2-3 quarts ASAP (and i mean ASAP like pull over and call a friend to bring you oil + a funnel, then check if you need more after that)
...thats if you value your motor, good luck.
4tika4
Aug 8, 2012 09:12 PM
b18c1v1c
12
Jan 4, 2008 10:31 AM
crazytalk
May 8, 2007 04:38 PM
duggy
May 14, 2005 10:12 PM
sharkey65a
Feb 7, 2003 09:55 AM
