oil level too high?
Old Aug 8, 2012 | 06:49 PM
4tika4's Avatar
Default oil level too high?
I have a b20b turbo. I recently changed the oil. drained all the oil, and removed the filter. I had 4 quarts of new oil total. I put some in the filter to prime it. them put the rest in the engine. I thought b20s took 4 quarts but my dipstick reads half a quart over the top dot. Thats when the car sits overnight. but when warm it reads a little under the 2nd dot.
whats going on?
Old Aug 8, 2012 | 07:37 PM
Fliptard's Avatar
Default Re: oil level too high?
all the oil is settling to the pan when it sits overnight? I would think.
Old Aug 8, 2012 | 07:44 PM
4tika4's Avatar
thats what i thought. but dont you check the oil when it sits over night? ive heard so many different theories on this. i let the pan drain all the drips for like 35 minutes. and put only 4 quarts in
Old Aug 8, 2012 | 07:47 PM
Fliptard's Avatar
if its only a tiny bit over, it's not a big deal.
Old Aug 8, 2012 | 07:49 PM
4tika4's Avatar
half a quart? maybe a little less
Old Aug 8, 2012 | 07:51 PM
Fliptard's Avatar
it'll be fine. Just gives you more time before you have to check it again. If you notice performance decrease or wierd noises for some odd reason, drain a little out.
Old Aug 8, 2012 | 08:00 PM
4tika4's Avatar
anybody else have input?
Old Aug 8, 2012 | 08:33 PM
MRGRIM's Avatar
R.I.P. Mark
if the drain back on the filter is not working it could be that
Old Aug 8, 2012 | 08:49 PM
4tika4's Avatar
but why would the oil level read high?
Old Aug 8, 2012 | 09:12 PM
MRGRIM's Avatar
R.I.P. Mark
myn reads high when cold but thats due to an oil cooler after start up it returns to normal
the only reasons i can think of ...
not all oil drain out when you changed it
oil filter capacity is draining back when cold
pjr710
Feb 6, 2009 10:23 AM
bopbop93030
May 13, 2008 04:30 PM
crazytalk
May 8, 2007 04:38 PM
94GsRacer
Sep 19, 2002 02:43 PM
dose
Aug 8, 2002 09:20 AM
