Timing Adjustment help plz
Old Dec 29, 2007 | 04:18 PM
Max_GI's Avatar
Default Timing Adjustment help plz
Hey guys, I just changed my timing belt and am trying to adjust my timing with my timing light. according to the specs, i should adjust it at 16 degrees. Anyways, everytime i go to move my dustributor, i keep getting some serious shocks, after the third time i simply stopped and called it a day and figured i would ask here for advice. anyone?
Old Dec 29, 2007 | 04:42 PM
z6hatchboy's Avatar
you may need new plug wires.
Old Dec 29, 2007 | 04:46 PM
Max_GI's Avatar
they are brand new ngk! or could it be distributor cap? or a ground wire missing from valve cover to chassis
Old Dec 29, 2007 | 06:26 PM
Historyg's Avatar
sounds like a ground wire for sure
Old Dec 29, 2007 | 06:27 PM
Max_GI's Avatar
are we suposed to be able to adjuste and move the distributor with the engine running?
Old Dec 29, 2007 | 06:44 PM
z6hatchboy's Avatar
Default Re: (Max_GI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max_GI &raquo;</TD></TR><TR><TD CLASS="quote">are we suposed to be able to adjuste and move the distributor with the engine running?</TD></TR></TABLE>
Yes, that is how its done. Does sound like a ground then though, because for some reason it not following its ground path and its jump to you.
Old Dec 29, 2007 | 07:39 PM
Max_GI's Avatar
Then that's going to be the first thing that i'm going to try tomorrow morning! hopefully that solves the problem!
meallout
Mar 19, 2009 11:34 AM
type-GGSR
Dec 26, 2007 09:52 AM
DC_RaceR
Aug 24, 2006 06:45 PM
krazn
Feb 22, 2004 11:11 AM
