Advanced Timing.
Old Dec 23, 2007 | 11:06 PM
type-GGSR's Avatar
Default Advanced Timing.
My friend plans to do his Advanced timing i think on his distributor. Is this even a good idea? If it is, will u feel it significantly?
Old Dec 24, 2007 | 09:49 AM
AWD Terror's Avatar
Default Re: Advanced Timing. (type-GGSR)
There is no reason to advance timing on a stock engine.
I herd if you take the distributor off it will run faster
Old Dec 24, 2007 | 03:46 PM
Blahblah718293's Avatar
Default Re: Advanced Timing. (AWD Terror)
i dont think its a good idea, you wont gain much of anything.
Old Dec 24, 2007 | 04:57 PM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-GGSR &raquo;</TD></TR><TR><TD CLASS="quote">My friend plans to do his Advanced timing i think on his distributor. Is this even a good idea? If it is, will u feel it significantly?</TD></TR></TABLE>
No and no and what he said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">There is no reason to advance timing on a stock engine.
I herd if you take the distributor off it will run faster</TD></TR></TABLE>
Old Dec 26, 2007 | 09:52 AM
Ls92's Avatar
I did it and didnt feel a difference,so I switched it back to 16deg btdc on my da.Here is where I found the info http://www.g2ic.com/tegtips/engine/7.html
Modified by Ls92 at 11:19 AM 12/26/2007
okbubbac
May 28, 2007 05:29 AM
JBirch_97Prelude
Jul 2, 2006 02:37 PM
Nicaraguense13
May 22, 2006 12:07 AM
Dunc
Jan 7, 2005 01:09 PM
hYpE-R-29
Dec 8, 2003 07:26 AM
