What is this extra plug? CX b16 swap
it is apart of the emissions equipment- i forget exactly what it is but i want to say evap purge. That is a jdm b16 using your stock engine harness?
It looks like the purge solenoid connector for a USDM engine. The JDM B16A does not have one (if that's the motor you've got there). Don't worry, the JDM ECU will not look for it and it will run fine. I had the same question when I did mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrg85 »</TD></TR><TR><TD CLASS="quote">where is it going to? on my 98 ex i put a jdm obd1 b16 and the plug looks like the oxygen sensor plug that goes to your headers. </TD></TR></TABLE>
O2 plug is not shaped like that and has longer wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon93 »</TD></TR><TR><TD CLASS="quote">if its 1 wire its ur knok sensor plug if it has 2 it could be evap sensor </TD></TR></TABLE>
Knock sensor has a different connector. Notice how your EVAP canister has one vac line unconnected? It would go to the Purge Solenoid on your old motor and your JDM motor does not have one. It will run fine without the Purge Solenoid and the unconnected vac line (just plug it at the canister) and it also will not set off a CEL.
Happy revving
Happy revving
wrong shape, completely wrong area in the bayy
hmmmm.... i have a 2000 Si head on my LS/vtec and thats hole on the manifold for that sensor is blocks off. so my sensor is just dangling around. doesnt affect my cars performance though. but mine does plug in to my harness though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_concept_eg6 »</TD></TR><TR><TD CLASS="quote">...thats hole on the manifold for that sensor is blocks off. so my sensor is just dangling around. doesnt affect my cars performance though. but mine does plug in to my harness though.</TD></TR></TABLE>
Sensor...or connector is dangling?
Plugs into harness...?
iiiNo comprende!!!
iiiNo comprende!!!
user 72830283
13
Sep 18, 2005 12:20 PM
ent0ne
Mar 26, 2005 06:37 PM
ablack934doorcivic
Sep 19, 2004 12:49 PM
