8:5:1 LS Turbo @15psi well made 322whp!!!!!
Old Dec 18, 2007 | 06:56 AM
95exdsmkilla's Avatar
Default 8:5:1 LS Turbo @15psi well made 322whp!!!!!
Beeyond Engineering did it again!!!
1993 LS with 8:5:1 SRP pistons, Eagle Rods, Stock Sleeves, OEM honda Bearings, OEM H.G, Stock head, 3 bar map sensor, aem fpr, aem fuel rail, and 880cc injectors. Beeyond Engineering Turbo kit with Beeyond Engineering Top mount with T3/T04E 57trim (ebay turbo, he was on budget). But it did the job... made 322whp.
A/F ratio was around, 11.3-11.6 on top end. But since we are in state of wisconsin, it was very cold lol. 25degrees.
Old Dec 18, 2007 | 07:09 AM
Chris Tune's Avatar
Default Re: 8:5:1 LS Turbo @15psi well made 322whp!!!!! (95exdsmkilla)
sorry but i fail to see the !!!! in it... its quite normal.
anyways good luck and tells us how it runs
Old Dec 18, 2007 | 07:32 AM
It was on crome forgot to mention lol.
This car runs like a champ!
Old Dec 18, 2007 | 07:50 AM
Schister66's Avatar
Man U FTW
I fail to see the amazingness of this...my STOCK BLOCK GSR made 7whp less than your built block....should i celebrate?
Old Dec 18, 2007 | 07:54 AM
mitsuman's Avatar
Default Re: (Schister66)
How much torque?
Old Dec 18, 2007 | 08:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">I fail to see the amazingness of this...my STOCK BLOCK GSR made 7whp less than your built block....should i celebrate?</TD></TR></TABLE>
I fail to see the amazingness of your gsr.... 7psi w/ gt32??
this car was with straight LS.
this car owner had Ls/Vtec mild built last year... ran 11.1@126mph with 360whp. He probably can out drive you my friend. Other than, on a LS w/ so low compression made this power, its pretty impressive.
Old Dec 18, 2007 | 08:10 AM
DC4KiD's Avatar
Default Re: (95exdsmkilla)
Good power for 15PSI on a .57 trim.
Old Dec 18, 2007 | 08:39 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95exdsmkilla &raquo;</TD></TR><TR><TD CLASS="quote">
I fail to see the amazingness of your gsr.... 7psi w/ gt32??</TD></TR></TABLE>
You would...if you would have read my sig, which you'd have to do in order to know i run a GT3255, you'd also know it was on 10psi. Regardless, there is no tech in this thread
jdmhondanation
May 8, 2011 08:07 AM
gotrice16
Jan 3, 2009 10:23 AM
duffmans92eg
Jul 21, 2006 03:05 PM
Andrea
Dec 22, 2003 02:21 PM
Yosshaa
Aug 2, 2003 07:37 PM
