CEL #3
Old Dec 17, 2007 | 02:04 PM
Malakai's Avatar
Default CEL #3
Hey guys,
Got a CEL this morning, so I just checked the code. It's a code #3 Map sensor.
What do i do to go about fixing this issue?
Thanks!
Car 98 dx d16y7
only mod- sri
Modified by Malakai at 6:12 PM 12/17/2007
Old Dec 17, 2007 | 03:08 PM
Malakai's Avatar
bump!
any ideas guys?
Old Dec 18, 2007 | 09:33 AM
Malakai's Avatar
bump.
no vacuum leaks as far a can tell....
Old Dec 18, 2007 | 10:15 AM
Relic1's Avatar
CEL3 is MAP electrical, meaning there is an electrical problem with the MAP sensor.
Double check that the connector on the MAP is seated and not dirty or corroded.
Old Dec 18, 2007 | 10:24 AM
Malakai's Avatar
since this is on a y7, is the MAP on the backside of the tb or the left side? (looking straight on at the motor)
Old Dec 18, 2007 | 10:55 AM
Relic1's Avatar
backside, a little to the right.
the TPS is on the left side.
Old Dec 18, 2007 | 11:25 AM
Malakai's Avatar
ok thanks! thats what i thought. I did a lil check this morning before work and everything was secure. Ill dbl check to be sure.
Will it hurt to drive in this state? The motor idles at like 12-1300 rpm. Will it just eat more gas?
Old Dec 18, 2007 | 03:05 PM
Relic1's Avatar
it will eat a lot of fuel, run like crap and may run hot.
fixing it is the best move, but if you can't fix it right away, keep a close eye on everything.
Old Dec 19, 2007 | 08:48 AM
Malakai's Avatar
yea seems to be eating gas at twice the rate, mainly cause of high idle. other than that it seems ok for now.
what would be the easiest fix? just get a new MAP sensor? there really is no junk yards around here where i can get one from. All the yards are for old domestic ****.
Old Dec 19, 2007 | 08:53 AM
Relic1's Avatar
have you been working in that area of the car?
maybe you have the TPS and MAP plugs switched.
Old Dec 19, 2007 | 08:54 AM
philosofy1's Avatar
Default Re: (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">yea seems to be eating gas at twice the rate, mainly cause of high idle. other than that it seems ok for now.
what would be the easiest fix? just get a new MAP sensor? there really is no junk yards around here where i can get one from. All the yards are for old domestic ****. </TD></TR></TABLE>
yeah most of the time a code 3 is a bad map sensor. if there are no salvage yards around you, you might want to try ebay. the some times have them for sale pretty reasonable. remember though that they are used, but in the same token, brand new will cause you to pay about $200 or more.
Old Dec 19, 2007 | 09:12 AM
Malakai's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">have you been working in that area of the car?
maybe you have the TPS and MAP plugs switched.</TD></TR></TABLE>
here is my orignal thread when stuff started happening...
https://honda-tech.com/zerothread?id=2174950
The battery and alt checked out. They are getting the proper voltage. The car was running better. kinda dropping in rpms, but nothing to make it stall out anymore. Then 2 days later i get the cel for the map sensor.
Is it possible the boost that i gave fried the sensor?
Old Dec 19, 2007 | 10:15 AM
Relic1's Avatar
did you have the battery checked out?
did you replace the alternator?
the problems may be unrelated if an issue was found... but a dieing MAP sensor may cause the car to run like you described.
basically any map sensor from a 96+ civic or OBD2 teg will work on your car.
honda part number - 37830-P0G-S00
Old Dec 19, 2007 | 10:25 AM
Malakai's Avatar
Yea both checked out fine. Thanks for the help!!
i'll look around and see what i can find! thx again!
Old Dec 19, 2007 | 10:35 AM
speedooo's Avatar
I agree...change the map sensor
hondalove414
Mar 20, 2011 08:11 AM
peedee
Mar 29, 2007 08:09 AM
Punker1234
Feb 4, 2006 01:20 PM
vtec25
Oct 6, 2004 08:26 PM
slowazzhatch
Jun 1, 2003 07:42 PM
