B16A and B18C water pump and timing belt compatible?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">what are you trying to do?</TD></TR></TABLE>
trying to rebuild b16a engine with higher compression pistons.cams.i might as well change the timing belt and water pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC »</TD></TR><TR><TD CLASS="quote">
trying to rebuild b16a engine with higher compression pistons.cams.i might as well change the timing belt and water pump</TD></TR></TABLE> Smart thing to do since the motor is off of the engine bay!
one thing to keep in mind is the b16a is exactly the same as the 94-95 del sol (b16a3) (as far as parts). the difference from the b16a/b16a3 from the rest of the b-series motors is the teeth on the pump and the crank, if you are going to use those from a b18/b20/b16a2 (they are all the same).
lv6l
10
Oct 13, 2005 07:27 AM
jdmEFsedan
Mar 3, 2005 11:18 AM
