HT HELP! Car will not start
Old Dec 10, 2007 | 11:03 PM
creepy116's Avatar
Default HT HELP! Car will not start
hey i just swapped in my ITR motor into my 99 coupe and i tried to start the car but all it does is crank nothing more. my friend was helping me out and he said there seems to be no spark coming from the spark plug wires. whats the problem?!?
Old Dec 10, 2007 | 11:06 PM
fmrprojects's Avatar
Default Re: HT HELP! Car will not start (creepy116)
check for correct firing order and that all the grounds are nice and tight
Old Dec 10, 2007 | 11:07 PM
Hardedge's Avatar
If it's a fresh swap it never hurts to triple check all connections.
Old Dec 10, 2007 | 11:22 PM
creepy116's Avatar
Default Re: (Hardedge)
firing order is correct! triple checked that **** lol and how many grounds are there exactly?
Old Dec 10, 2007 | 11:23 PM
creepy116's Avatar
Default Re: (creepy116)
are you guys familiar with the CKF bypass? i didn't do that but would that be a factor?
Old Dec 10, 2007 | 11:44 PM
creepy116's Avatar
help!
Old Dec 11, 2007 | 12:35 AM
SLO Sol's Avatar
check your grounds! or it could be your distributor
Old Dec 11, 2007 | 12:38 AM
creepy116's Avatar
Default Re: HT HELP! Car will not start (SLO Sol)
alright ill get back to you on that
Old Dec 11, 2007 | 04:03 AM
almerricking's Avatar
i had the map and tps sensor mixed up and thats what prevented my car from starting.
Old Dec 11, 2007 | 09:35 PM
creepy116's Avatar
Default Re: HT HELP! Car will not start (almerricking)
new update: i got my dizzy checked today and the dizzy is fine. i checked my spark plug wires and there is a spark. CAR STILL WONT START all it does is crank
Old Dec 12, 2007 | 07:01 AM
hurtgen's Avatar
"how many grounds are there exactly? "
valve cover, transmission, and block i think?
Old Dec 12, 2007 | 04:32 PM
creepy116's Avatar
Default Re: (hurtgen)
anybody help me?
Old Dec 12, 2007 | 04:33 PM
WhiteOnRice's Avatar
Does the fuel pump turn on?
Old Dec 12, 2007 | 04:37 PM
creepy116's Avatar
Default Re: (WhiteOnRice)
is there gas going to the spark plugs? yes there is
Old Dec 12, 2007 | 04:39 PM
So you get gas and spark? Did you run the engine before buying it?
creepy116's Avatar
i just changed my cap so sparks should be flying! but car still not running :[
Old Dec 12, 2007 | 04:41 PM
creepy116's Avatar
no i didnt run it before buying it but earlier i changed the firing order to see if anything would change and flames came out of my header(my header is not bolted to my cat)
Old Dec 12, 2007 | 04:47 PM
b18 EK9's Avatar
I know your problem there is a ground that goes by your thermostat housing that is going to be not put on im almost sure thats it i had the same problem if not e-mail me cobraz240@hotmail.com and i will help you fix the problem
Old Dec 12, 2007 | 06:31 PM
vlc92189's Avatar
Default Re: (b18 EK9)
how did you check for spark?
you might think you have spark, but you dont. if i was you take a ignition coil frm someone else's distrubutor and try it out, that is what my problem was
Old Dec 12, 2007 | 07:07 PM
creepy116's Avatar
Default Re: (vlc92189)
i checked and the thermostat ground is on. i know there is spark because i took each spark plug wire out and put a spark plug into it and cranked the car and i saw sparks
Old Dec 12, 2007 | 07:14 PM
creepy116's Avatar
i also do not have the intake air temperature sensor and 2nd o2 sensor plugged in, i dont know if that would matter
Old Dec 12, 2007 | 07:45 PM
creepy116's Avatar
anyone else?
Old Dec 13, 2007 | 08:45 AM
b18 EK9's Avatar
take the fuel regulator out and open the key and see if fuel comes out. It could have fuel pressure but take the regulator out to see if the fuel flows that far the reason I say is because on the fuel rail the stud were the fuel line goes might be diffrent there is 2 types check that for know get back at me and let me know
Old Dec 13, 2007 | 01:06 PM
creepy116's Avatar
Car is running now! :] the timing was wayyyyy off, thanks everyone for giving me your advice though
em1_fox
Oct 28, 2007 12:11 PM
909ej195
Oct 9, 2006 08:31 PM
btrim23
Apr 24, 2004 04:52 PM
blackhatchy
18
Apr 13, 2003 05:27 AM
reese
Sep 2, 2002 11:59 PM
