bad idle problem
Hey guys I have a 2004 Honda civic si..it has a full turbonetics turbo kit on it..and ever since ive had it..it has a horrible bounce in the idle..and once it quits it just sits at 2k RPM..a lot of people told me to clean the IAC and I did and it did nothing...also there was a place for a coolant hose i guess on the bottom with nothing going to it so I capped it off but that didnt help either
..any help would be appreciated thanks
When you say since you've had it, does that mean the turbo kit has been on since you've had it, or did you get it, see it had an idle problem and still proceed to put a turbo in it?
no it was turboed when i bought it and has had the idle since I bought it...im going to check for a boost leak or a vacuum leak tomorrow when i get off of work and see if thats it..but if not im lost..I dont know a whole lot about turboed cars so I really dont know where to start right now lol..thanks
yea the guy at the dealership told me he could get the guys number for me..so if i dont find a boost leak or something im going to give him a call and see what he says..thanks..ill keep you posted
Wow you dont know much about turboed cars and you went ahead and bought a USED turboed car with a bad idle. That wasnt too smart man. What map sensor do you have? Do you have Kpro? Is the CEL on? Have you checked the TPS? Good luck fixing your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS »</TD></TR><TR><TD CLASS="quote">Did you rotate the air in your tires. You should be running on winter air. Check the muffler bearings? Check the halogen blinker level fluid?
What are you tuned with?
I have the cybernation piggyback unit...someone on ephatch told me to get ahold of them and see if they can give me a different flash for it...and someone else told me that i need to get rid of that and get a Kpro cuz i will end up blowing my motor with the cybernation unit..but the sole purpose of the cybernation unit is to keep from blowing the motor thats why if you are running to lean or to hard it will kinda bog down for a few seconds...but i dunno
I would go with the kpro. Forget about bogging out from running lean sometimes, I'de rather have my car run right all the time. Get Kpro and get it tuned. I wouldn't drive it until then, because it sounds like you don't know what kind of tune the person before you had.
the only thing I know about the tune is he had it done at central florida turbo..so obviously its going to be a good tune...other than that I have no idea..but i am going to get the Kpro asap i just dont have that kind of money right now because of christmas and bills..sucks when you start getting older and have all these damn bills to pay lol
the gaurdian that comes with cybernation kits is as flexible and usefull in tuning as the emanage..which is garbage.
I tried calling cybernation in the past to get help with the gaurdian and they're very unhelpfull.
I think kpro is your best bet for a solution. If it was a vaccuum leak the rpm should be a little more sluggish than usual too.
Keep us posted.
Keep us posted.
nope no Check engine light..its runs really great besides the idle..but yea i definently will get the Kpro asap and let you all know how that goes..im trying to save right now but its hard to save around the holidays...thanks for all the help
crxfreak1117
Sep 8, 2007 07:05 PM
Boostless97Lude
Jan 15, 2003 11:05 PM
